Results 21 to 30 of 35
Thread: Anyone else using Exact Audio Copy to burn CDs onto a hard drive?
  1. #21
    interestingly i used to use it on a xp and vista laptop but on won 8 or 10 it never worked right for me or was basically unusable. not sure if it worked on win 7
    Mine is running Windows Vista, and goes like a steam train
    SW1X USB II
    SW1X DAC III Special
    SW1X Open Baffle Speakers containing both vintage and modern alnico drivers and paper cones. All silver wired and crossover-less where possible - 4" vintage Siemens Klangfilm tweeters, 8" SEAS exotic W8 midrange drivers and vintage 15" Altec VOTT 416 bass drivers
    DRD 45 single ended, 45 triode, monoblocks,
  2. #22
    I'm Tom.
    There's a lot of bloatware that comes with newer PCs now - I was shocked at how much when I was setting up my wife's fancy touch screen Lenovo she uses for work, all sorts of games, pointless utilities, trial applications and so on, much of it set to load into memory on start-up. It took an hour or more to get rid of it all. I suspect though that some people would be reluctant to delete this junk as it 'comes with the machine'. That could be part of your problem with the original PC or laptop. That and the fact that the program itself needs updating to run properly on modern operating system versions.
    https://www.computerworld.com/articl...rid-of-it.html
  3. #23
    Thanks Tom for the info. That makes good sense as the old laptop was wiped of all stuff ready for dumping. It wont even go on the Internet, which means I lose some of the labelling bits of EAC, but I don't care.
    SW1X USB II
  4. #24
    I'm AMusicFanNotAnAudiophile.
    I take it you're entering track details manually, before ripping?
    Chris
    Common sense isn't anymore!
  5. #25
    Can live without it. I just use the CD jewel case or I cant be bothered to even move then I use Shazam
    Not a lot different to reading a vinyl album cover.
    SW1X USB II
  6. #26
    I'm Edward.
    Chris, why can't the old machine go on the internet? Have you tried connecting the machine to your router with an ethernet cable? I find even with ancient machines, so long as it boots, connecting to the internet with ethernet always works.
    EAC has an excellent hit rate for finding correct metadata. And if you want to find metadata for rips you have already done use mp3tag.
    Main: Tidal/Roon > MiniITX > Metrum Hex > LDR > either Radford STA25 V or Trilogy 968 > Tannoy (Eaton or Berkeley).
    2nd: Tidal/Roon > Roopio on Pi > Chevron Paradox > Firebottle Buffer > Sugden Masterclass IA-4 > Kudos Cardea
  7. #27
    If you're sure it's the way to go .......
    Chris
  8. #28
    Quote Originally Posted by Edward View Post
    He's ripping to WAV - metadata not supported.
    That said, at least the files would be correctly named...
    Chris
  9. #29
    I'm Edward.
    Well that certainly has been true for most of the time tagging was implemented Chris. However since recently (2016?) tagging in wav files in a standardised way has been implemented by most audio software. ID3v2 tags are now (can be) added to an extra chunk at the end of the wav file. MP3tag, JRiver, Microsoft to name but three software packages implement embedded wav tagging.
  10. #30
    Thanks Edward.
    Last time I looked (and I'm fairly sure it was within the last couple of years, although it could easily have been longer) it wasn't supported.
    I've just done some WAV ripping using dBPoweramp, and I can read tags using Mp3Tag.
    Chris
