Looking for a DAC that also has a preamp built in with a remote also! Up to £500 is my budget.
Cheers all
Cheers all
nice little dac which it can be used as a pre amp , we heard this at a coherant demo once and it did not disgrace
https://www.ebay.co.uk/itm/Bel-Canto...gAAOSwyHRapjqe
Eric Bibb
If you don't need a phono stage then the first model Quad Vena is a very versatile DAC with a respectable integrated amp ... but also has outputs to use as a Preamp:
Couple on the bay at the moment under your budget:
https://www.ebay.co.uk/itm/Quad-Vena...MAAOSwLzxdIL~Q
https://www.ebay.co.uk/itm/QUAD-VENA...gAAOSwE3FcxGPH
I have had one for a couple of years now and been very pleased with it
Thanks chaps, ill have a
