Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: AVO Two Panel Tester
    I'm Justin.
    Default AVO Two Panel Tester
    Just dug this out.
    Tried to test a 45. Basically it doesn't work.
    It powers up fine. Heater voltage set to 2.5V and looking at the filament that looks about right in terms of glow for a 45. Set 4V and it's too bright. I therefore believe it is supplying about the right heater voltage.
    Anode is set to 100. Select anode set to normal. Set mA/V switch is set to mA/V marking.
    With these settings it should be possible to set the meter to read zero. However, that's impossible and the lowest value I can back it off to is 4.8 mA/V. But then it slowly rises see 2nd pic.
    The Philco 45 is working and known to be good. The switch settings for a 45 are correct according to the AVO Data Manual.
    Conclusion is it is bust. I have known that for a long time.
    Anyone on the forum know how to fix these meters?
    Mod fix the title to AVO?
    Cheers.
    I could take a look at it for you Justin old boy.
    I like a challenge
    I'm Justin.
    Alan like the sound of that.
    Will PM at some stage over the weekend.
    I'm Justin.
    Just spotted in a computer repair shop in Clifton...
    Retro cool.
    I'm alan.
    A O Tester....?
    What....... Tests Amps, Ohms but no Volts.
    I'm Justin.
    A few internal shots.
    Couple of caps which I suspect are from around 1938.
    The main concern seems to be the state of the large tranny.
    Alan please take a quick look. I don't know whether that looks repairable. Don't want to send it on if it looks doubtful. But we do know that large tranny supplies about the right heater voltage (amazingly).
    I'm Justin.
    Some more...
    It looks old, it is old, with insulation materials to match.
    I will definitely replace the two wax capacitors but I doubt there will be a problem with anything else.
    I'm Justin.
    OK will try and post out tomorrow.
    The wiring insulation is shot in places. But I can't see anywhere where it would cause an actual problem. It may be prudent to correct the obvious issues where they can be seen.
    I think the issues it has are deeper rooted than the two caps and wiring, so enjoy trying to suss it out
    Does the unit have a 4 pin socket suitable for 211 valves?
    If not have you a spare 4 pin socket you could send as well?
