Results 1 to 10 of 15
Thread: Isoacoustics Iso-pucks speaker isolation
    I'm Bruce.
    Default Isoacoustics Iso-pucks speaker isolation
    Isoacoustics products seem to be among the better engineered and performing isolation for speakers and the Iso-puck is a bit more cost effective than the Gaia series, whilst using the same technology. Whether combatting wooden flooring or general desire to improve speaker performance…
    I have four pair new, sealed in box, which will support two speakers up to 80 lb (36 kg) each. I’ll sell the lot for £160 delivered on UK mainland.
    Bruce
    Theories are not so much answers as questions, to be supported or undermined by experience & testing.
    Source: Audiolab 6000CDT > Calyx 24/192 DAC
    Amplification: Pass-design B1rev2 pre-amplifier > Neurochrome Modulus 686.
    Loudspeakers: Proac Response 1SC
    Cables/stands: spkr: MIT MH-750 biwire; IC: HT Truthlink; Target stands, sand-filled; Excel Cat6A 23AWG UFTP & 1attack.de Cat.7 SFTP.
    Other: Balanced AC transformer to hydra mains distr; Bass traps & Acoustic panels; Isolation: Inner tube & roller bearings; 3xZyxel ES104A switches in series w/Vreg upgrades.
    I'm Phil.
    gosh thats a good price , someone grab these before i succumb , i bought a load of them a few months back
    Eric Bibb
    I'm Barrington.
    These are serious speaker tweeks for heavier speakers. Go grab a bargain.
    I'm Phil.
    Only 9kg per pucks so not too heavy !!
    Eric Bibb
    I'm Robin.
    Probably rules my speakers out as they are 22 kg each
    Regards
    Robin
    Pathos Classic Remix Amp, dac
    Cyrus Signature phono stage
    Eversolo DMP-A6
    Cyrus CD i
    I'm John.
    Quote Originally Posted by rmcin626 View Post
    NOPE.
    As last time I checked 4x9 = 36 and your speakers are only 22.
    I'm Vince.
    Yep they will certainly support your speakers.....in fact you would only need 3 per speaker, that would equate to 27 kg. Bloody good price as well. Glws
    I'm Robin.
    Thanks John and Vince, should have read the post properly
    Regards
    Robin
    Eversolo DMP-A6
    Cyrus CD i
    I'm Phil.
    Quote Originally Posted by Vince View Post
    they can be a bit unsteady with 3 , tried it already
    Eric Bibb
    I'm Barrington.
    Yep I agree ended up using 4 each under my Ushers.
