Results 1 to 9 of 9
Thread: Short USB cable and long interconnects or long USB and short interconnects
    I'm William.
    Default Short USB cable and long interconnects or long USB and short interconnects
    Hi Guys
    I think the above explains it all. I currently have my DAC close to the amp and use short interconnects, my laptop is at least 2.5m away from the DAC. I could move it round with a bit of effort. But thought I’d ask the question first so long USB cable and short interconnects or the other way round. What will give best quality?
    Many thanks
    Regards
    Bill
    2.5m? I doubt you'd hear any difference at all quite honestly. USB is designed to work up to 5m and then MAY require active repeaters to maintain a connection, but good quality line level RCA cables should be good for 5 to 10m. YMMV as usual.
    Nottingham Analogue Spacedeck / Kuzma Stogi S / Benz Micro Ace S L
    Lenco L-75 / Carl Ellis Plinth / Ortofon AS-212 / Ortofon SPU Classic GM E MkII
    Ortofon ST-7 SUT / Nick G Modded Lentek Head Amp / Croft RIAA
    Cambridge Audio CXU / Theta DS Pro Prime
    Classé Model 30 / Luxman M-383
    Usher Compass X-719
    May contain opinions that others find disturbing.
    I'm Neil.
    Long USB cable will be cheaper, and more convenient. At these lengths nothing to worry about sonically.
    Usb is usually good for 5m. 10 with a repeater cable. I used to use a 10m with repeater in middle a lot and there is no degradation that I can hear. Not overly expensive either.
    I'm Russell.
    What kind of USB cable are you using? Just a standard computer store type? Or one claiming to be for audio use? A better cable MAY make a difference, or it may be hardly noticeable. They do come in all prices, perhaps an entry level USB for audio cable would be worth an experiment, like those made by Audioquest, but I wouldn’t spend any more than would hurt your feelings if it didn’t make a difference.
    Russell
    I'm Bill.
    Try a Lindy USB cable - quality cable at a good price!
    Chord Mojo / Sennheiser HD600
    I'm William.
    Hi Guys
    I’m using a Belkin Gold series cable. I’ve had it for some time now, it was well thought of when it first came out. It was said that it was good value for money performance wise, probably could be bettered now though. I think it is now discontinued.
    I'm Neil.
    Quote Originally Posted by Pegwill View Post
    Hi Guys
    The Belkin is an ok starter cable, but having done comparisons with Wire World USBs I did hear a difference, between them, with the Wire Worlds being better. I haven't played with other audiophile USB cables, but I would assume there will be differences, and improvements to be had there too.
    I use up to 2m with no issue, not tried longer.
    Regards Neil
    I'm Neil.
    Quote Originally Posted by Bourneendboy View Post
    +1
