Results 41 to 47 of 47
Thread: Breaking earth loops
  1. #41
    I didn't post the picture of the isolating transformer box as a cure to anything.
    I was just showing a bigger, more complete version of the XLR model Ali posted.
    The cure is, as you've already pointed out, tracing the loop and then breaking it.
    I wasn't criticising the use of an isolation transformer, just pointing out that if mains hum has already got into the signal path, fitting a transformer downstream of the signal is not going to stop it.
    If however the mains hum is due to an earth loop, and it is not possible or convenient to fit earth lift resistors, then a 1:1 transformer placed in the signal pathway is a neat way to break the loop. But in adding an extra component into the signal path, the quality of the isolation transformer is important in respect of both frequency and phase bandwidth.
    I note the transformer unit is fitted with XLR connectors. I would have thought if using fully balanced interconnects between items having true dual-differential input/outputs, mains hum breakthrough would not be a problem.
    Just realised my computer that controls the miniDSP is plugged in a separate wall socket, so I can sit with it on my lap.
    I plugged it in the same place as the other five components and the earth hum has receded again. I think I can live with this ��
    Interesting topic. Thanks for your help.
    Source
    SW1X USB II
    SW1X DAC III Special
    Audiolab 6000 CDT transport
    Amps
    Speakers
    BK Electronics XLS400FF Sub.
    Cabling
    Headphones
  3. #43
    I'm AMusicFanNotAnAudiophile.
    Laptop?
    Chris
    Common sense isn't anymore!
  4. #44
    Laptop?
    Yes the computer holds the program that controls the DSP in the bass circuit. Once the parameters are cemented I can power it with a 5 volt linear power supply.
    Source
    SW1X USB II
    Amps
    Speakers
    Cabling
    Headphones
  5. #45
    There is no mains ground continuity from the machine to the plug in the board.
    So there can't be a ground loop there.
    If plugging the laptop PSU has quietened things down then it's a good move, but I'd be bothered that a SMPS PSU was plugged into the same power block as the rest of my gear.
    Sticking a ferrite clamp us close to where the power cord plugs into the laptop PSU would reduce the effects of switching noise (aka RFI).
    We humans can't hear it, but amplification devices see it, and they're adversely affected by it.
    Chris
  6. #46
    With mains connected equipment it is a safety requirement, that the chassis including its top and bottom side front and back metal work
    have access to safety ground. http://sound.whsites.net/articles/mains-safety.htm Whilst double insulation creates a different set of
    requirements, the majority of equipment requires chassis to be firmly connected to safety earth.
    Light Dependent Resistors happen to work exceptionally well to stop ground loop issues in audio equipment, having the side benefit
    of improving signal to noise ratio, and as a result the appreciation of music. An article here explores transistor based opto isolators
    that also have the same benefit : https://saaubi.people.wm.edu/Teachin...roundLoops.pdf
  7. #47
    Quote Originally Posted by Light Dependant Resistor View Post
    It's a laptop computer.
    It's double insulated.
    Chris
