Results 21 to 30 of 47
Thread: Breaking earth loops
  1. #21
    I'm struggling too. If you put a resistor between the ground of the cable and a case that is not connected to earth, then its seems no better than inserting a resistor and dangling the other end in fresh air.
    I agree, I think Ali is suggesting that the resistor is inserted in the 'ground' connection out to the output sockets.
    As far as an earth lift goes in an earthed case system, the extra resistance between the signal ground loop and the earth loop forces any current that is flowing to flow in the earth connections between cases, rather than the signal connections, thus reducing the 50Hz currents to virtually zero.
  2. #22
    I think that is clearer !!
    Let me try this. If I take a wire from one of the cable earths through a resistor and then to the mains earth is this the same.?
    SW1X USB II
    SW1X DAC III Special
    SW1X Open Baffle Speakers containing both vintage and modern alnico drivers and paper cones. All silver wired and crossover-less where possible - 4" vintage Siemens Klangfilm tweeters, 8" SEAS exotic W8 midrange drivers and vintage 15" Altec VOTT 416 bass drivers
    DRD 45 single ended, 45 triode, monoblocks,
  3. #23
    Also, using a passive with transformers will also break the earth loop.
    I had a passive once which did just that.
    Sent from my 9001X using Tapatalk
    Transformers will only provide galvanic isolation, that is isolation from DC. Any alternating current fed to the primary (such as 50Hz mains 'hum' and its harmonics) will be simply transferred to the secondary winding of the transformer.
    I once had a mild hum problem with an AV set up. Using a 1:1 transformer did not help. The only cure was to trace the earth loop and break it.
    I'm Neil.
    I wonder if itís an interconnect related issue, specifically with how the shields are being grounded.
    What interconnects are you using?
  5. #25
    Only providing the cable earth isn't directly connected to mains earth, this is where the 'earth lift' comes in.
  6. #26
    Great I'll give that a go. Some googling suggest a capacitor in parallel to the resistor is a good idea. Don't know why?
    SW1X USB II
  7. #27
    I'm AMusicFanNotAnAudiophile.
    Coz it blocks DC.
    Chris
    Common sense isn't anymore!
  8. #28
    I'm Edward.
    At times I've experienced horrendous or minor hum and scratched my head searching for causes, blaming it on earth loops, bad components and all else between. So far as I recall the hums went away by realigning interconnects and speaker cables, often only by a small amount. What I call 'jiggling'.
    I offer no explanation as to why (I'm not an electronics engineer), just what I found (so far).
    caveat: YMMV.
    Main: Tidal/Roon > MiniITX > Metrum Hex > LDR > either Radford STA25 V or Trilogy 968 > Tannoy (Eaton or Berkeley).
    2nd: Tidal/Roon > Roopio on Pi > Chevron Paradox > Firebottle Buffer > Sugden Masterclass IA-4 > Kudos Cardea
  9. #29
    I use Klotz cables around the DSP circuit. These are certainly quieter than the Audionote silver cables I used before.
    SW1X USB II
  10. #30
    Coz it blocks DC.
    Is this a worthwhile thing to do?
    SW1X USB II
