Results 1 to 10 of 10
Thread: Hello
    I'm Morris.
    Default Hello
    Here to learn and contribute where I can.
    Bought my first audio gear at 17, Akai and Aiwa with Wharfedale Laser 60 speakers.
    Now I have a bit more stuff (don't most of us) and other than getting an SP10 at some point and constructing my own speakers I am settled with what I have.
    Of course, that could change
    Primary
    Tubelab SE300B
    TEAC TN-400 w Shure V15IV & SME3009 Imp
    Vista Phono1+
    Loth-X Ion BS1 & Rel T-Zero 2
    Bluesound Node 2i
    Secondary
    Denon DRA-455
    Genesis 2+ (upgraded crossover)
    Bluesound Node 2i
    Emotiva XDA2
    Backup
    Dual 1219 w/ Shure M91ED
    TEAC TN400
    Sony DVP -7000
    Office
    TEAC AH-500 and associated components
    Bose 301 IV
    Some Pictures
    Alex_UK's Avatar
    Welcome to the forum Morris. Must admit Iím not up to speed on most of your kit - maybe show us a photo or two sometime? Anyway, glad youíre enjoying your system and hope you enjoy AoS.
    Alex
    I'm Morris.
    Thanks Alex, I put up some pics but they came out quite large! And look at that dust
    The tube amp I built with help from friends and is a design by George at tubelab.com. Puts out about 7.5wpc.
    The Loth-X Ion BS speakers are a terrific bookshelf speaker and when paired with the Rel t-Zero 2 are a perfect pairing with my tube amp. Specs on those are:
    Tweeter: 1-inch treated cloth
    Main driver: 6-inch paper (Loth-X custom) w/cloth surround and magnetic shielding.
    Frequency Response: 55 - 20,000Hz
    Impedance: 8 Ohms
    Efficiency: 94dB/2.83 V/m
    Dimensions: 200mm x 295mm x 400mm (WxDxH)
    Weight: 12kg
    The TN-400 is an interesting turntable with magnet float technology and is a broadcast table form the 70's to compete with the Technics. Plinth is plyboo built by a good friend of mine.
    The Genesis II+ speakers are again from the 70's with an eight-inch two-way system with a ten-inch passive radiator. I replaced the crossover components with modern equivalents to the same specs.
    Dimensions: 33" x 14-1/2" x 10-1/2"
    Weight: 44lbs
    Sensitivity: 88.5 dB, 1w at 1m
    Frequency response: 28 Hz to 20 kHz
    Power: 15 - 100 watts/ch
    Impedance: 8 ohhms
    I'm Shane.
    Howdy! Welcome to AOS.
    Have fun.
    S.
    Shane Lonergan.
    Home Hi-Fi Chat UK (Facebook Group)
    Welcome to AoS Morris.
    That's some fine gear you have there - I didn't know TEAC had made a turntable, and your valve power amp looks to have a high build quality. Well done!
    What are your tastes in music; what do you put through your system(s)?
    Enjoy the Forum
    I'm Morris.
    Thanks Shane/Barry.
    Tastes in music: hard to narrow down to be honest. From Chicago Jazz of the twenties through to Vampire Weekend with classical; opera; blues; rock; pop; and a bunch of other stuff in-between.
    I'm Russell.
    That tube amp is beautiful! Well done! If it sounds half as good as it looks, then itís really something!
    Iíve pondered building myself a tubed amp, but so far I havenít made the plunge, your amp is inspirational!
    Russell
    I'm Morris.
    Russell
    Russell,
    Thank you.
    I thoroughly recommend giving it a go. It took me a very long time as I kept losing confidence in making it safe. In the end I took what I hoped was a near as dammit finished amp to a chap who repairs them and he worked his magic to ensure it was safe and worked a treat.
    Very satisfying to know that me, a couple of mates and someone who knows what they are doing built an amp together
    I'm Russell.
    Quote Originally Posted by moggi1964 View Post
    Russell,
    Thank you.
    I studied a little electronics in college, some 25 years ago, so hopefully I could manage! And Iím sure there is literally tons of help here on this forum, you canít swing a cat without hitting an expert! I donít think I could go wrong?
    Russell
    I'm Andy.
    Welcome aboard Morris
    Analogue
    301 / 3012 / dl 103
    401 / PU7 / AT33ev
    RD Technology Godolphin PSU/speed contol
    Longdog Audio MC1J Prototype
    Digital
    Vortexbox, SBT
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage, or Quad 44
    Quad 303, or Bel Canto Set 40 or NG 300B Set Monoblocks
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
