Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
Thread: Passive pre-amp
  1. #21
    I'm Richard.
    Apology required from me given subsequent explanation.
    Saw initial post and was irked by it.
    My mistake.
    Sorry.
  2. #22
    That's the one. Conductive plastic fared better here. Yes it may be 3 times the price but it has to be a better investment.
    I do have a £3 conductive plastic pot somewhere and I felt that was better than an alps blue too.
    Go for the best: https://www.cw-industrialgroup.com/P...entiometer-RCP. They are fitted in the preamps I use.
    Bigman80 Guest
    Have you compared them to Khozmo or similar Barry?
  4. #24
    Quote Originally Posted by thingfish View Post
    Kiss.......is a great concept and that should be a passive pre requisite.
    But.............
    It's more complex than that.....or is it really?
    If you think of a attenuator in terms of being simple and that simplicity to be exactly where the audio path goes - what is the simplest ?
    The answer is in the image. A variable resistor with no contacts coupled by light.
  5. #25
    I'm alan.
    Now that as Spock would say...is Ilogical captain !!!
  6. #26
    Yet it is the simplest in terms of audio path being preserved, and at the same time being a variable attenuator and a switch for inputs in its Off state
  7. #27
    Bigman80 Guest
    LDR are proven to add distortion
    Simplest isn't the key.
    Lowest distortion is where the OP should be aiming.
  8. #28
    And lowest distortion is with a good LDR circuit.
    LDR's simply reflect back how good or poorly the anode and cathode are driven, do that well and distortion
    disappears, however do that poorly and figures and graphs you are poised to paste, are what results.
    What does it take to drive the anode and cathode correctly, is what you need to ask. You also need to ask
    yourself why graphs of distortion are not provided with potentiometers passing audio signals ?
    https://pinkfishmedia.net/forum/thre...tortion.68076/
  9. #29
    Bigman80 Guest
    Quote Originally Posted by Light Dependant Resistor View Post
    Alps and the like do add a modicum of distortion, which is why I moved to Stepped Attenuators.
    There is a forum that offers free measurements of HiFi equipment. Why not send them one of your preamps for testing? I'll try and find a link.
    Have your Stereo Coffee preamps been tested already?
    I am afraid independent testing with published measurements consistently support the claim that LDR's drift over time and add distortion.
  10. #30
    I think you are referring to Audio Science Review - I am nearly ready to send Amir a cased unit to review.
    I too thought stepped attenuators were good, which was in 1992 hearing them with Vishay bulk foil resistors
    Just as Rob expresses here in the last paragraph https://robmid42.wixsite.com/diyaudi...ich-ldr-preamp
    stepped attenuators are not very high on the list, when compared to LDR's
    Both of your presumptions, expressed as fear, are wrong.... which time will prove. There should be a review
    at Pink Fish forum in about 3 weeks, sorting through what sounds best.
