Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: BOSC - HiFi Monoblock Class-D Amp
    I'm Edward.
    Quote Originally Posted by orchardaudio View Post
    If you are really interested in this product and would like to be one of the first people to get it at a reduced price, reserve now for $1. Only 55 spots available:
    https://orchardaudio.com/shop?olsPag...ts%2Fbsc-mplfr
    Does a reservation imply an obligation to purchase? If so what is the purchase price please?
    Is $1 for a pair of monoblocks or just for one amp?
    I'm Leo.
    Quote Originally Posted by Edward View Post
    $1 is for a two amplifiers. If you only need 1 we can work something out.
    There is no obligation to purchase with the reservation.
    Full pricing and updated specs here:
    https://orchardaudio.com/bosc
    montesquieu Guest
    Default BOSC - HiFi Monoblock Class-D Amp
    Ok so long as there’s no obligation I paid my $1. Curious about these as a bit of a class d fan but will need more info before proceding.
    I'm Leo.
    What info are you looking for?
    montesquieu Guest
    Lots of questions. Are these just class d only? Any input stage? Damping factor? What’s the current delivery like? Pics/specs of the power supply? More to the point how do they sound with various types of speakers? (Subjective obviously but even informal reviews on forum can provide valuable info).
    If you look at the info provided on design approach and topology for the NuPime ST10 and STA9 amps - both excellent class d amps, but also a good example of how to sell class d. They have class a input stages btw.
    I'm Leo.
    It is a full class-d amplifier using gallium nitride (GaN) output devices in a full-bridge configuration (fully balanced output). The modulator is fully custom and proprietary. It is not based on any modules like nCore or ICE.
    I just measured the damping factor at 1kHz to be 425, so for the specs I will say >400. More importantly BOSC allows you to suspend the amp from the back of the speaker eliminating long cables which can hurt a great damping factor (see picture below).
    The input stage is a Texas Instruments OPA1612 which in my opinion is the best audio monolithic op amp currently available.
    The Power supply is a 56V 250W swithing power supply - All tests and specs are performed and measured with this power supply. (see picture below)
    I am not able to comment on how they sound, but I can say that they will have no issues with driving any kind of speakers. A review will be out shortly. Also a member of this forum has agreed to try them and post findings. That will be a few weeks.
    montesquieu Guest
    Thanks that's all very useful info, thanks. I see the pic shows balanced input which could be handy in many cases.
    It seems to be quite the thing at the moment for Class D manufacturers to add a discrete input stage, sometimes single ended, sometimes tweaked in some way (in some cases I believe even by digital singnal processing) to give a small amount of first and second harmonic associated with tubes, with the stated intent of giving a warmer/more triodey feel to whatever Class D main board is in use. It's interesting that you have opted to stick with an op amp - no doubt for the distortion specs and so on you mention.
    I'm Leo.
    The AMP has a true balanced input, but also comes with an RCA to XLR adapter for those that would need it.
    How well do these amplifiers perform when used with electrostatic speakers? I would consider using them with my Quad '57s.
    Thanks
    I'm Leo.
    Thanks
    I do not have this type of speaker. I don't see any issue with it. The performance will still be very good as long as the load presented to the amplifier is in the 4 to 8 ohm range.
    Where are you located I can potentially send you sample units to try in 3 to 4 weeks.
