Results 1 to 10 of 16
Thread: Original colour of Garrard 401 platter?
    Default Original colour of Garrard 401 platter?
    Hi, guys do any of you have a mint 401 platter? Could I ask a favour? Could you Please post a picture so I can examine it for my 401 resto project.
    Many thanks
    A
    PRE
    I'm sorted.
    This do you?
    That's great, how would you describe the outer, darker part? Matt black? Also, do you know if the whole of the platter was the same colour or two tone like yours?
    PRE
    Maybe dark gray ( gunmetal ?) then wire wool to rub down the central part to blend it to that lighter colour?
    Looking at others photos on the net most seem to have that shading towards the middle.
    i agree with you, I've done a couple of hours searching on the net and all you see is the two-tone variety
    PRE
    I'm sorted.
    Yes, definitely matt & it all looks original to me.
    I'm Paul.
    Mine is the same. As far as I can tell it looks like before final finishing the edge of the platter was sprayed. The two tone looks like overspray from not masking the top of the platter. Once sprayed the platter was turned to bring out the strobe indicators and the top edge of the rim.
    ~Paul~
    Alex_UK's Avatar
    Mine isn’t as black
    Alex
    I'm Andy.
    Mine looks pretty much identical to Roy S
    Analogue
    401 / PU7 / AT33ev
    Digital
    Innuos Zen Mini Mk 3
    Topping D50s
    Caiman Seg & Dorado
    Cambridge CXC
    Amps
    Tron Seven Linestage
    Speakers
    Tannoy GRF Memory.
    Tannoy ST100.
    I'm mark.
    They're very dark brown/black rather than grey/black, the 301 does look black.
    Same as anything, the painting did change, I've an early 401 which is smooth, almost 301 enamel, I've had later 401's with fine textured finish.
