Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Home Built Arcade
    I'm Paul.
    Default Home Built Arcade
    For anyone who has fond memories of the old stand up arcade machines you can build your own these days if you have the time and inclination.
    Mine started off as a bartop arcade which I bought as a shell in raw mdf flat pack form. The display is an old dell pc monitor. The brains is a rpi running retro pi as the software.
    I found a website that could supply the rest: buttons, joysticks, wiring loom, speakers etc... and with a bit of help from my bro we got it up and running first time.
    It was an enjoyable project and not difficult buy any means although you probably will need a bit of IT knowledge and a good few man hours.
    As it was being put away and not used much I've just finished a stand I made from a single slab of 2.4m x 1.2m 18mm MDF and b&q doing most of the important cuts. Hopefully now it will get a bit more use, by my kids and me.
    Sent from my CLT-L09 using Tapatalk
    Current system:
    RPi + Allo Digione
    Beresford Caiman Seg & Dorado powered by 15v Linear PSU
    Transcendent Sound Mini Beast OTL
    Amptastic Mini-1
    Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
    110aH Leisure Battery powers the Mini-1 & Digione
    Outstanding.
    I was after one of the old tabletop ones for years but they are so expensive. I noticed you can get kits now but I'd never get round to it and I'm totally cack-handed. Which you obviously aren't. Settled for one of the Atari retro consoles instead.
    Has it got a selection of games on it or just Pac Man?
    Alex_UK's Avatar
    Top job there Paul! Fabulous.
    Alex
    I'm Paul.
    Cheers lads.
    Macca it's got about 300 old games on it and not just arcade. Some of the early console games are available and all selected from a pretty home page.
    A couple of things left to do like moving the power socket so I can have it flush up against the wall and might install some better quality sanwa sticks over the soft and unresponsive zippy ones currently installed.
    Current system:
    RPi + Allo Digione
    Amptastic Mini-1
    I'm Ben.
    Looks like a proper professional job, well done mate.
    Sent from my EML-L29 using Tapatalk
    Technics SL1210 with
    SME IV Arm & AT OC9XML,
    Firebottle modded Tron Convergence Phono Stage,
    Bluesound Node 2i, Technics SL DZ 1200 CD
    Denon PMA1700ne amp
    Yamaha NS1000M Speakers.
    I'm Neil.
    Quote Originally Posted by Pepperamip View Post
    Cheers lads.
    Would definitely upgrade to Sanwas. PS your cab job is awesome, super clean.
    Cheers lads.
    That's brilliant. I really want one.
    I'm Paul.
    Give it a go, it's easier than you think
    Current system:
    RPi + Allo Digione
    Amptastic Mini-1
    It would have to be a lot, lot easier than I think. Yours looks perfect. Mine would look like a ten year old with ADD had built it. And it probably wouldn't work.
    I'm Paul.
    Lol holes are already drilled fro buttons and sticks and you even get a wiring diagram with it. Only got attach the spades to the relevant terminals.
    Here's what you are after:
    https://www.ebay.co.uk/itm/DIY-ARCAD...AAAOSw1R1aufet
    Current system:
    RPi + Allo Digione
    Amptastic Mini-1
