Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 127
Thread: My Tannoys grew up
  1. #21
    " Need to find new Tannoy 4 pin plugs possibly. Fit new speaker binding posts."
    https://www.ebay.co.uk/itm/One-new-b...D/152683403098
    Here you go. I'll be using these on mine when I can be bothered to uprate my Tannoys X-O.
    PRE
  2. #22
    Great thread by the way. I love my 15" MG's. Always seem to surprise me in what they can do.
    PRE
  3. #23
    Or, if they are sounding wonderful, just leave them alone. Not every tweak is necessarily an improvement.
  4. #24
    I'm Shane.
    Agreed.
    S.
    Shane Lonergan.
  5. #25
    I'm Edward.
    Snap! Tom put me onto these earlier on. Have you decided yet on what internal wiring you will use Andrew? I see you will be using WBT silver binding posts. Nice - and expensive!
  6. #26
    I'm Edward.
    This is very true Geoff - but where is the fun in that?
    The cabs need tidying up so may as well do things whilst the drivers are out.
  7. #27
    They look fine and fancy, but has anybody actually measured the resistance through them compared to the originals when plugged in? Or checked what material they are made from? Also, I would not be surprised if the contact area is reduced and what is the outer spring blade section made from, steel maybe?
  8. #28
    I'm Edward.
    Quote Originally Posted by hornucopia View Post
    Weekend reading?
    https://jeffsplace.positive-feedback...view-system-1/
    Lots of stuff about external X-overs, wires etc..
    Thanks V much Chris - pure audio porn!
    I'm trying to do this on the cheap you know. You're not helping!
  9. #29
    I'm sorted.
    Quote Originally Posted by Edward View Post
    Original cone surrounds? Looks like the driver may have been out at some stage & caused the scrape in the paint when it was being wrestled back in.
  10. #30
    Yes Paul at RFC uses them, he's knows his onions.
    PRE
