Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: FR64 FX arm - your thoughts on this dilemma
    Default FR64 FX arm - your thoughts on this dilemma
    I currently own a Fidelity Research FR64FX arm, silver wired version ( so it says on the box ).
    Whilst I can't prove that the arm is indeed silver wired ( they usually have a sticker on the arm tube, this one doesn't but it might have come off at some time prior to new owning it ).
    I've always had the niggling doubt that the edge/glare on the highs that irritates me was caused by the silver wiring, why go I think this, well anything I've tried that's silver wired has given me the same annoyance.
    So ..... Yesterday, I put my Mission 774 arm back on, bit of a faff as the metal sme armboard wasn't the right fit for the Mission baseplate so it's on but it's a bit Heath Robinson with odd screws etc, but it's firm and it works, the result? All that irritating edginess has gone, however it's not ' quite ' as good as the FR arm but it's close, I suppose you could say the positives do out weigh the negatives, ie: I'm not rushing over to the amp to turn it down before my ears bleed! But I do know I want better. I've lost a tiny bit in the bass and mid-range with the 774, more in tone than impact if you know what I mean but I can live with better than I can the ear bleeds, so a new arm isn't out of the question, especially as I know the FR is sought after.
    Now to my dilemma.
    1: Do I rewire the FR arm ?
    2: Do I try just changing the RCA cabling from the arm base to the phono stage?
    3: Internal rewire AND new RCA cable
    4: Sell the FR as is ( keeps it's original ) and buy as good an arm with no silver in it?
    I'm tempted initially to try 2 as it's easiest option even though I know putting the FR arm back in is a bit of a hassle. But will this help as the arm itself will still be silver wired, I mean is there any silver in the original RCA cable?
    Please note that this issue is the same on the FR arm no matter which of my three cartridges ( MM and MC ) or settings I use on each of the phono stages I've owned since buying the FR arm so I'm pretty convinced that's the cause.
    Your thoughts?
    I'm inthescottishmafia.
    Try another cable as you say, it’s quick and easy to do.
    FWIW, I had my 774 rewired with Ikeda silver wire by Johnnie, it sounded great and no edginess, but I think some silver wires can exhibit this. If a different cable doesn’t cure it, I’d send it to Johnnie to rewire with copper.
    Or just sell it if you fancy trying another arm lol. Guess it depends on how much you like it.
    Hunter S Thompson
    Interesting how close the 774 is though, the FR is a revered arm, so the Mission is in good company!
    Hunter S Thompson
    Increase the fluid damping on the 774 with a larger paddle or thicker silicone fluid, the bass will improve.
    The 774 benefits from a high quality rewire. The cable out to the phono stage can be improved on too. The mid and top will benefit.
    Yes it does. The Ikeda wire made a big improvement.
    Hunter S Thompson
    774 is very close Ali, if you hadn't heard the FR you wouldn't miss it if you know what I mean.
    The 774 is your old one so it's cardas wired and now has Olis Spotfire RCA cabling which is brand new so that might change over time.
    Geoff, I've a thicker paddle fitted and it's 'just' touching the oil at present, see above for wiring info.
    I should also say that the currently fitted metal armboard will be holding the 774 back but I traded Magna Audio Ebony one back in to buy the FR one, typical
    Bigman80 Guest
    Now to my dilemma.
    Your thoughts?
    Sell the FR.
    Buy a PMAT1010 or whatever your heart desires.
    Don't mess with the wiring as it'll mess with the value.
    Bigman80 Guest
    Yes, let that cable burn in. BASS will improve. The Mission is a drier arm tonally so don't expect rich mids.it won't do it.
    I tend to immerse the paddle. Try that and see if the bass livens up.
    Sell the FR.
    That is my fear, don't want to mess with the originallity of the FR in case I do sell it.
