Results 1 to 10 of 15
Thread: dr feickert adjust+ software.
    I'm jamie.
    Default dr feickert adjust+ software.
    has anyone else used this to set up azimuth? a kind sole over on pfm loaned me the software to use.
    i am truely shocked at the sonic results since using it to set my cartridge up,my ortofon kb was out by 1 degree when the headshell was level which i roughly new by eyeing up though a jewlers loupe but i could never get it right by ear.
    i though it didnt matter too much but the graph tells a different story.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Slav.
    Jamie your crosstalk level is quite low @20dB , try to play with VTA till you get at least 25dB .
    I'm jamie.
    cheers,ive played with the vta a bit but the crosstalk always stays around the same figures,the trouble is it pains me to move it as its sounding so much better than before,vta is set pretty much bang on imo as it is.
    chris at dr feickert has suggested that i should aim to get the phase angles intersecting at 90 degrees but id have to drop the arm so much i think the sonics would suffer.
    this is all new to me so feel free to add more advice please.
    My System
    John Wood KT88 Amp.
    I've got the Adjust+ system but never really messed around with it! I suppose I should dig it out of the loft.
    PRE
    I'm jamie.
    or sell it to me lol
    seriously though you should,its a powerful bit of kit.
    My System
    John Wood KT88 Amp.
    I'm jamie.
    Quote Originally Posted by mac72 View Post
    i think thats just the nature of the cartridge,ive just dropped and raised it 4mm and nothing dramatic happens to the cross talk levels.
    My System
    John Wood KT88 Amp.
    I'm Slav.
    With Cadenza Blue I was getting into high 20’s , with Bronze over 30 so it’s bit surprising.
    What’s your tracking force set to ?
    Usually on all cartridges I’ve checked crosstalk and phase angle crossed over within 0.5 degree , don’t worry about intersection at 90 degrees I’ve had a conversation with Chris and it is bit of unproven, it worked only with 2M Black out of all carts I tested.
    I'm jamie.
    ah ive just recognised who you are!
    tracking force is set to 2.7g.
    do you think its worth going over it again? ive done it a few times so far and it gets easier the more times you do it (as you probably know)
    i cant see it suddenly jumping up in the cross talk figures though ,the best i got was 22.5 and 20.5,never got anywhere near 23
    My System
    John Wood KT88 Amp.
    I'm Slav.
    Quote Originally Posted by karma67 View Post
    2.7 gram seems to be quite high , try to play with tracking force a bit as it changes SRA .
    Have you tried to test frequency response yet ?
    If you want to keep Feickert for bit longer it’s not a problem ,
    I'm jamie.
    Sorry I got that wrong, it’s 2.57,Ortofon recomend 2.5.
    I’ll give that a try and see what figures I get.
    My System
    John Wood KT88 Amp.
