Results 1 to 10 of 19
Thread: Pre and power , ON/OFF sequence?
    Default Pre and power , ON/OFF sequence?
    I am currently following the same procedure as I read on a naim site .
    In regards to my Alchemist pre & power is this correct:
    Power on :
    Sources
    Power supplies and preamp
    Power amp
    Power off is apparently the reverse.
    Cheers
    Exactly.
    Though, if it was a Naim, you would have to leave it to warm up for 3 months or else all the 'prat' goes out the window.
    Exactly.
    Thanks Dave
    always good practice to have vol at zero before you do any of that. interestingly my quad does exactly that by itself, lowering vc to zero before coming on.
    Grant .... ؠ
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2 - IFI PURIFIER 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - LEAF HD BLUETOOTH - OPPO PM-3 PLANAR, SONY H900 & NURAPHONE HEADPHONES - ZBOOK/ IFI SILENCER/WIN10 PRO/AUDIRVANA 3 PLUS/TIDAL - SMSL M6 DAC & IFI SILENCER - RPI 3+, DIGIONE HAT/VOLUMIO2 - FULL RANGE TWIN TELEFUNKEN SPEAKERS - CABLE INC CHORD, MOGAMI, SUPRA & WIREWORLD
    **Men are not punished for their sins, but by them**
    I do just that mate, still get that little thud though
    Probably doesnt have a soft start section; if its naim it wont have. Not much u can do bar disconnecting speakers. Amps having speaker switches were handy for that.
    Grant .... ؠ
    I'm Neil.
    I tend to flick the source selector to a non-active input too, because I tend to leave my gear on, but switch my hot Class A DAC off when not in use.
    I'm Mark.
    Exactly.
    I thought that only happened when a dealer stops selling it.....
    100% Analogue
    Not really. Some dealers have always always thought the 3 month warm up thing was ridiculous.
    I always kept the Naim bits n pieces powered on all the time which, I believe, is the recommendation..
    It's the one thing I miss about the Naim's ... as I don't leave the ML's switched on so have to wait just a little while for them to heat up a bit....
    Does anyone know if I could indeed leave the ML's switched on the whole time? The only reason I switch them off at the moment is that they both get pretty warm, unlike the Naim's
    Bev
    Mark Levinson N.390s CD Through: MG HDX1 To: Mark Levinson N.383 To: Magneplanar .7's
