The devil makes work for idle hands.......
So i set about a little idea i had brewing,to upgrade the signal pins in my RCA plugs to silver tube.
https://www.cooksongold.com/Tube/Ste...prcode-RSA-004
Once the tube arrived it was just a matter of cutting to the required length and filing down from 3.5mm to 3.25mm to fit.
Some sanding and a good polish with t-cut and there you go.
[IMG][url=https://flic.kr/p/SaNJgz]IMG_3312[/url[url=https://www.flickr.com/photos/145822004@N02/[/url][/IMG]
