Results 21 to 30 of 32
Thread: What happens if remove 1 wire from speaker?
  1. #21
    I'm Philip.
    In that case i'll increase the price!
  2. #22
    It's not the speakers, it's eBay, everyone there is just magic.
    Really
  3. #23
    I'm Craig.
    Default What happens if remove 1 wire from speaker?
    There are more idiots on eBay than just about anywhere!
    Bluesound Node 2i
    Audio Analogue Pucinni SE
    B&W DM607 s2
    Klotz ic’s
  4. #24
    Wonder if anybody's ever bi-wired not realising the links need to come out?
    I did by accident. Not good even with protection circuits in the amps...
  5. #25
    With links in, it makes no difference if you plug in bi-wire cables or single wire cables.
  6. #26
    I'm Dennis.
    If you analyse the circuit and draw it s equivalent you will see that under these conditions the only difference is paralleling the current conducting paths.
  7. #27
    But only if two wires are actually connected between amp and speaker I presume? The OP was suggesting that just one amp to speaker conductor is enough, not a pair...
    I suggest that his post falls into the 'miracle at Lourdes' category.
  8. #28
    Oops I meant biamp.
  9. #29
    On the original question, crazy idea but is there any way the -ve terminal can float and the voltage on the +ve cause a charge/discharge in the voice coils enough to make a sound? Given the mass of the cone/coil assembly I assume not, maybe the lightest most sensitive speaker could exhibit slight movement.
  10. #30
    I'm Deleted.
    No
    Account Deleted
