Results 1 to 3 of 3
Thread: Vitavox S2 compression driver to loudspeaker horn fitting rings
    Default Vitavox S2 compression driver to loudspeaker horn fitting rings
    The pair of Vitavox S2 compression driver to loudspeaker horn fitting rings are now tapped and fitted with Imperial threaded studs, washers and nuts.
    All ready to be sent to their new home in Canada.
    Sent from my Pixel XL using Tapatalk
    I'm inthescottishmafia.
    Lovely job as always Steve.
    Hunter S Thompson
    Thanks
