I have decided to sell my Audioplan mains distribution system comprising a PowerStar SII seven-way mains distribution block, a Fine Filter System Filter and a PowerPlant 100.
Audioplan is a well regarded German company that was extolling the virtues of a clean mains supply well over 30 years ago and long before the concept was recognised in the UK. In keeping with German tradition their products are carefully designed, manufactured to a high standard and offer audiophile performance.
PowerStar SII RRP £550
The PowerStar S is designed and built in Germany to UK specification. According to Audioplan it is a highly advanced and patented star-earthed mains power distribution unit with 7 high grade UK mains outlets (MK). The design of the PowerStar minimizes the differences emanating from the plug position of components called equalizing currents, which flow through the audio frequency lines to compensate for dynamic potential differences from the power mains. The PowerStar removes these differences and establishes a direct reference to the main component in the system, the preamp or the power amp.
This represents a decisive advantage in comparison to more conventional power distribution units. The PowerStar S is additionally fitted with Antispike component feet to provide maximum protection for acoustic vibration and give regulated damping to this unique product and comes complete with a high quality power cord fitted with a C19 plug.
SPECIFICATIONS
Supply voltage: 240 V AC
Power rating: 16 A
Output: 7 UK sockets, binding post for ground-connection
Internal Wiring: Silver plated pure copper conductors with 3mm2
Enclosure: Resin and 3 mm thick aluminium bolted together with 6 posts made from AntiSpikes
Feet: Additional AntiSpike bottom plate and AntiSpike component feet.
Cable: PowerCord S 1.5 m, other lengths on order
Size: Diameter 22 cm, height 11 cm (incl. feet)
Weight: 2.4 kg including 1.5 m cable (integral cable included in sale)
In excellent condition and complete with separate Audioplan power cable and original box. Asking £200 plus postage.
Fine Filter S RRP £595
According to Audioplan ''The FineFilter is a primary filter and is a highly resistant, universally applicable collective filter for audio and video systems with such low impendence, that even the largest power amps can be accommodated without any loss of dynamics. This is achieved utilising the highest quality components, manual wiring, and customising some of the components. The built-in safety reserve is to very high audiophile standards. The components of the FineFilter S can therefore withstand continuous current of 25 amps. This ensures that even the most extreme current peaks can flow without being limited by the filter. It also ensures the filter itself does not generate any interference due to saturation or overload effects (giving long-term stability). The filter is used to filter out audio interference, which would otherwise reach the system through the power mains and as such, it represents a vital component in the Audioplan Power system.
SPECIFICATIONS
Power rating: 10 A continuous, 16 A 40% ED
Over voltage protection: Yes
Filter characteristics: 3, switchable
Ground filter: Yes, switchable
Design: Hand-wired, moulded against microphonics
Enclosure: 5 mm cast aluminium
Supply: Hard wired 0.85 m PowerCord S''
In excellent condition with original box. Can be positioned in front of the PowerStar (or any other) distribution block to improve system performance.
Asking £220 plus postage.
PowerPlant 100 S RRP £625
According to Audioplan ''The PowerPlant 100S is a secondary filter (to be used after the FineFilter S or similar) to decouple components from the mains and to prevent them from emitting RF interference into the power line as well as to protect them from power interference. The unique design incorporates multiple nested windings, numerous layers of shielding and a specially made and tuned filter components to provide filtration and high levels of ‘reverse damping’.
The PowerPlant S is extremely effective with a wide range of AV components, including digital products such as CD Players, DACs, DVDs. It can also be utilised very effectively with Phono preamplifiers and Tuners.
SPECIFICATIONS
Power rating: 100 VA continuous
Overload protection: Thermal
Filter: 6-level nesting
Output: Floating, zero direct current
Supply: Hard wired 0.85 m PowerCord S ''
Although the most expensive of the three items being offered for sale and in good working order, please note that the plastic housing containing the internal fuse is damaged. Having experienced worthwhile improvements with upgraded fuses in mains plugs I decided to check the fuses on the FineFilter and PowerPlant with a view to possibly upgrading them. The fuse in the FineFilter screws into the enclosure and was easily removed, however, it transpires that the fuse in the PowerPlant is a push and twist design which when I tried to unscrew it broke the plastic securing lugs. Unfortunately, the fuse holder cannot be removed from the enclosure because it and the transformer are completely potted in resonance reducing mastic and are inaccessible. I secured the broken fuse holder back in place using heavy duty tape (see photo) and have since used the PowerPlant without problem. The use of tape does mean that the fuse can still be accessed if required.
No original box but will be well packed in an alternative box. Asking just £125 plus postage bearing mind the damaged fuse holder.
Reviews:-
https://www.google.com/url?sa=t&rct=...7MFsKf9WhdDgUq
https://www.google.com/url?sa=t&rct=...2YmEoIC4vbAtb6
