Results 1 to 5 of 5
Thread: Cambridge Audio CXN
    I'm Paul.
    Default Cambridge Audio CXN
    Last weekend I picked up a CA CXN. And to say I’m chuffed with the SQ is an understatement. My Mdac+ is gathering dust now and will be for the foreseeable. Been able to A B using a Graham Slee Solo headphone amp into senn 700s. The app is a bit chunky with Tidal and I can not seem to find master quality albums using the app on my iPad. Anyone who is looking at a mid price out of the box steamer could do a lot worse than one of these.
    I'm Terry.
    Default Cxn
    I have owned the cxn a few yrs now.
    Dam excellent sq, one of the best I have heard.
    You should play some dsd tracks, I know it converts dsd to pcm but, sound is awesome.
    I'm Paul.
    Thanks pal. I will defiantly try that. I don’t have any dsd tracks but will have look at getting some.
    Quote Originally Posted by Kamo View Post
    I've noticed that the Master versions are listed first when searching, eg: if you look for an album and it lists two versions, the Master seems to be the first one listed. Not sure if those is 100% accurate but it was how I found most of them when searching particular artists.
    This was in the Tidal app itself, the Cambridge app might do the same.
    I'm Wolfeschlegelsteinhausenbergerdorff.
    They are great units....wait till you hear the Azure 851N though
