Results 1 to 1 of 1
Thread: Vitavox S2 compression drivers mounting rings
    Default Vitavox S2 compression drivers mounting rings
    A pair of screw on horn fitting adapters for the amazing Vitavox S2 compression drivers.
    Under creation.
    Made to original format.
    From 4" round aluminium bar stock.
    Features large 16 threads per inch imperial screw thread cutting.
    Then tested for smooth fit on my own Vitavox S2 drivers.
    Original Imperial thread fitting studs to go - unique to Magna Audio
    Sent from my Pixel XL using Tapatalk
