Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Quad QC Twenty Four P Phono Stage for sale
    I'm Graham.
    Default Quad QC Twenty Four P Phono Stage for sale
    Current spec model in unmarked condition. Bought in September 2016, brand new.
    Designed for Quad by Tim de Paravicini, it supports both MM and MC carts (using onboard transformers). It includes 3 gain settings for each of the MM and MC inputs. It also includes a by-passable volume control so can be used without a separate pre-amp.
    It uses four 6111WA military spec valves with a rated life of 100,000 hours. I always turn it off when not in use, so estimate usage at under 1500 hours.
    See http://www.quad-hifi.co.uk/product-detail.php?pid=17 for more details.
    The unit has just been serviced by Quad at Huntingdon and has been checked on test to full factory specification.
    Please note any marks visible in images are dust, smudges or reflections, I can’t see any marks on it.
    Supplied with original packing, power cord, manual.
    For a short time only I can offer the unit for £525 delivered as I can get it sent directly from Quad to the buyer.
    Please read the photo rules Graham. https://theartofsound.net/forum/announcement.php?f=22
    Yours are too small.
    I'm Graham.
    Hi Walpurgis,
    Can you please suggest a suitable free file hosting site, and I will move it.
    Many thanks,
    Graham.
    tinypic, imagur, or use tapatalk on a mobile
    If it helps, here's a guide to using http://tinypic.com/ I wrote a while back.
    lordmortlock Guest
    Here you go Graham
    I'm Graham.
    thanks Grant :-)
    I'm Graham.
    Thanks Jake, how did you do that?
    lordmortlock Guest
    Tinypic. Works well when it isn’t bombarding you with clickbait!
    I'm Graham.
    bump
