Results 11 to 20 of 28
Thread: Help with my bright ( to me ) sounding system
    I'm Neil.
    I've got a pair of subs I'm gonna have a play around with tomorrow, see how I get on after that.
    But room treatment could be something to think about, thanks
    Rega RP8, Rega Ania MC Cart
    Moded Lenco GL75, Jelco 750D, Denon 103
    DIY Transcendent Sound Phono, Firebottle OTP II Phono
    The Truth Linestage
    Firebottle AIR
    DIY Matteis Aspen HDL with Jordan Eikona 2 drivers
    Usher Dancer Mini 2
    I'm Brian.
    Oliver's correct regarding the interconnects . I would try a heavier copper speaker cable and see if that works .
    Regards
    Brian
    Amplifier : Sony TA FB740R
    Speakers : Tannoy 637
    Could be at cart side,
    I'm Adrian.
    Quote Originally Posted by Shadow Moses View Post
    Just the valves that was sent with the kit for the Phono stage
    Can't remember of hand what they are but prob the cheapest.
    I bought the cartridge last weekend, been breaking it in most of the week, had a Rega Ania before that, was also the same, same lean sounding so don't think it's the cart.
    This hobby is bollocks sometimes.
    So many variables
    Hi,
    Your system as others have said should be good, I haven’t heard Ushers but it could be them as others have said, however you say TT and cartridge is new. I tried out a Hana SL a few weeks ago and is a good cartridge, good bass and smooth mods, and sweet top end, very good VFM. But have you checked that The VTA is set right for it, for most the arm should be parallel to the record. If the back of the arm is up then it will enhance the top and if down will enforce the bass. Some cartridges are tricky to get right and once you hit the sweet spot the sing with detail across the frequency Randy range. Worth checking it might be fine.
    I'm jamie.
    as above,start with the basics,set the cartridge up first and then move on from there,1 thing at a time.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    Plumbing in the subs may well be worth a try Neil, they will give your sound a bit more 'welly' for a given volume setting, so your amp should then be less 'worked'.
    Could be the Usher speakers, according to HFW they measure flat in room which means they will sound a bit lean. http://www.hi-fiworld.co.uk/index.ph...o.html?start=3 and I'd expect the Jordans to be even leaner.
    You've got a Rega and a Lenco deck, does it sound lean with both? Some/most belt drive decks sound a bit thin in the bass but Lencos don't tend to so is the problem there with both decks?
    Would help if you have a digital source to compare with so that the variables of the vinyl set up can be bypassed, if it is still lean with the digital then it's not the decks at fault.
    I wouldn't piss about with cables until you've eliminated the more likely possibilities. The speakers look like the culprit to me though, especially if the room is a fair size and you have a bit of space about them I'd expect them to sound a bit bright and thin. Don't fall into the trap of blaming the recordings!
    Bigman80 Guest
    I can help with that Neil. Could plumb my speaker cables in and see what happens?
    I'm Phil.
    went to a great bake off which included the ushers . i didnt think they were particualrly bright
    https://hifiwigwam.com/forum/topic/1...owbray/?page=9
    might be worth playing with some different amps and pre amps perhaps .
    Eric Bibb
    I'm Neil.
    Thumbs up
    Cheers for the reply guys,
    I've added a sub this morn at 50hz that's helped a lot.
    Alan Firebottle has kindly offered to come over and have a listen, he's gonna bring a bit of kit with him so hopefully we can pinpoint it
    The Truth Linestage
    Firebottle AIR
    Usher Dancer Mini 2
