Anyone here using Atlas Speaker cables, Interconnects etc? Any good?
S.
S.
Shane Lonergan.
I'm Shaun.
Hey Up Shane I've been using Atlas Hyper interconnects for a good few years now. I have compared them to many others but the Hyper cables are bloody stunning. I use them between DAC and preamp and also pre to power. The sound is full and strong and the stereo image is huge and very wide in comparison to QED interconnects and also cheaper Atlas (Equator) interconnects.
I'm Dominic.
They are good, well made, simple no nonsense cables that are not pumped up with any hype.
CD player = Marantz CD6006
DAC/pre = Rotel RC 1572
Power amp = ADA PF201
Speaks = Quadral Chromium Style 6
I'm Shaun.
No Shane only the Equator ones.
Thanks, Shaun.
S.
Shane Lonergan.
I’ve got a pair I no longer use, think they’re pretty well made and work well. I’ll check the model name and let you know.
I'm Richard.
Atlas cables are all excellent and good value. The secret is the purity of Copper and as you go up the ranges, the construction is that much better than most other makes.
The Element Superior Integra incons have been very popular with my customers.
The only negative, as far as I am concerned, are the hard to remember names.
