Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: VPI
    Default VPI
    A few shots of the VPI Scout 1.1
    [IMG]P1090207 by [url=https://www.flickr.com/photos/162281319@N03/]J[/IMG]
    [IMG]P1090206 by [url=https://www.flickr.com/photos/162281319@N03/]J[/IMG]
    [IMG]P1090205 by [url=https://www.flickr.com/photos/162281319@N03/]J[/IMG]
    [IMG]IMG_1472 by [url=https://www.flickr.com/photos/162281319@N03/]Flickr[/IMG]
    [IMG]P1090209 by [url=https://www.flickr.com/photos/162281319@N03/]ckr[/IMG]
    [IMG]IMG_1470 by [url=https://www.flickr.com/photos/162281319@N03/][/IMG]
    VPI Scout 1.1 - Ortofon 2M Black FGS - Croft 25R+ - Croft Series 7 - Spendor SP2
    I'm Oliver.
    Pure filth!
    Analogue: Technics SP10 MK2 > Phonomac AT-1010 MK6 tonearm > Ortofon Kontrapunkt b > Bigbottle Jfet MC Valve Phonostage (Telefunken Valves)
    Digital: Raspberry Pi 3+/Allo Boss 1.2/Isolator 1.3 & 2x LPSU's with Volumio & JRiver
    Amplification: Nelson Pass DCB1 with Khozmo 48 Step Series Attenuator & Krell KSA100 MK2 Amplifier
    Cables: SPOTFIRE Speaker Cable & SPOTFIRE IC Cables & SPOTFIRE Tonearm cable
    Speakers: Pioneer CS-77A
    Price List For SPOTFIRE Cables here:https://bit.ly/2Uxiv3j
    Alternative reading: http://www.audioaddictsforum.com
    Analogue porn!!
    Tangerine LP12,Naim Aro, Benz Wood
    Hovland HP100 MC
    SiriuS D100
    Quad FM4,RWA Cassabria + LCD 3
    Wilson Benesch Actors
    I'm Tony.
    Nice pics Jim.
    What's the mat, any improvements over riding bare back?
    VPI Scout 1.1, Ortofon Quintet Bronze, Vanderveen MC10 SUT, WAD Phono3, Rpi3B+/Digione Signature, Xiang Sheng DAC-01, WAD KiT6550 and Reiver Edingdale SR
    The mat is sorbathane and was supplied with the turntable. I disliked it at first but when you spend 2000 on a turntable they are hardly going to give you a mat that underperforms. I have tried many other mats but unbelievably nothing sounded better or quite right other than this cheap piece of sorbathane.
    So VPI got it right although I think they do supply other mats and also recommend bare back playing.
    I'm Robert.
    Claasy looker Jim
    My System:
    Turntable - Modified Technics SL1210 MK5G
    Mike New precision bearing, bearing base plate, ETP Platter
    Micro Seiki MA-202 tonearm, rewired, hybrid ceramic bearings
    Ortofon Cadenza Black moving coil cartridge - Fritz Gyger S re-tip
    Yannis Tome 423.5 Silver-Litz tonearm cable with KLEI Pure Silver Harmony plugs
    Ebony armboard
    Audio Technica MS-8 Magnesium headshell, Ortofon pure silver headshell leads
    Isonoe Isolation Feet
    Paul Hynes SR7EHD PSU (plus regulator modules), DCSXL pure-silver DC lead with Jaegar low impedance connector
    CDP - Pioneer PD-91
    QED Silver Spiral speaker cable, Airlock plugs - bare wire amp end.
    Mains - Ultra Pure silver plated un-switched socket, Missing link EPS 500 silver plated plugs with Hi-Fi Tuning gold plated silver ceramic 13 amp fuses
    Claasy looker Jim
    Thanks Rob. It will be the only turntable I will ever have now unless I have a windfall and can afford one of the higher models but some of them are eyewatering price but probably sound eyewateringly good!
    I bet it sounds as good as it looks::)
    That looks a better mat than the one supplied with mine. Couple of questions Jimbo, what have you placed beneath the motor unit? And where did you get that slab of carbon fibre?
    WEBSITE.... www.theprogmeister.com
    Golf, a good walk spoiled : M Twain.
    Quote Originally Posted by Floyddroid View Post
    Hi Steve, the mat under the motor unit is an Amazon mouse mat! Does a great job isolating any motor vibration. The large slab under the turntable is compact laminate. It feels as heavy as granite and is made of thousands of layers of some material set in resin I believe. This sits on some sorbathane feet and does a very good job of Isolating the turntable from any other vibration.
    As you know the turntable is massively heavy itself with a huge sheet of thick steel bolted under the plinth. The cone and ball feet add further Isolation.
