Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Mark Grant HDX1 interconnects
    I'm Shane.
    Default Mark Grant HDX1 interconnects
    Might get some in a couple months.
    Anyone here using HDX1? Any good?
    Cheers.
    S.
    Shane Lonergan.
    Bigman80 Guest
    Quote Originally Posted by southall-1998_mk2 View Post
    Cheers.
    S.
    Not a fan.
    Bass heavy, thick sounding cables.
    But some Mogami and laugh at how much you've saved in comparison for a far more balanced sound.
    Here:
    https://rover.ebay.com/rover/0/0/0?m...2F321722857474
    I'm Shane.
    Not a fan.
    Here:
    I don't want to see tonearm cables.
    S.
    Shane Lonergan.
    Bigman80 Guest
    S.
    I was showing you the cable, Shane, as a point in the right direction.
    Here's a direct link to the interconnect version:
    https://www.ebay.co.uk/itm/Mogami-25...-yEk2cayTvSagg
    I'm Shane.
    OK, thanks. Just to point out. The item location is based in Greece.
    S.
    Shane Lonergan.
    I'm Wolfeschlegelsteinhausenbergerdorff.
    S.
    The cable is an RCA, but with added earth bond. Nothing special about it being a 'specific tone arm' cable.
    I have a set of HD1X, and they are nice, but they do have a low end bloat.
    However I now use Mogami as a balanced cable for my TT, and Oriton Orange Symphony as an RCA, which for me, is the best RCA there is.
    However there are ranges of Mogami cable, so its best to do some research first as to which one you want to use.
    Personally, I'd just a Mogami terminated with Harmony plugs over a HD1X, but if you really want a HD1X drop me a PM as I may as well sell mine.
    S.
    You can buy Mogami at HHB direct or plenty of sellers on eBay making their own. Oliver is jsut giving you visual examples to look for elsewhere....obviously.
    I'm Shane.
    Quote Originally Posted by The Chronicals View Post
    It's for my simple headphone set up. Just to link my CD Player to the Headphone amp. Sound wise, just something smooth and balanced. Without adding/taking away etc. Which particular Mogami interconnect do you recommend?
    S.
    Shane Lonergan.
    S.
    Mogami 2549
    You can buy it direct from HHB off the real, then choose your own plugs. Its not hard making an RCA if you have a soldering iron.
    Bigman80 Guest
    S.
    The one in Greece. Its 2549 I think and it's very good for the money.
    Not sure why the location is an issue but whatev's!
