Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Reducing low end output.
    I'm Rich.
    Default Reducing low end output.
    Hi all,
    I use a pair of Impulse Lalis, which I believe are a horn loaded design.I absolutely love them, but I do find myself worrying about how much low end they kick out. Not in terms of the overall sound, but in regards to disturbing my neighbours. I live in a block with people above, below and to one side of my lounge, I find myself listening at lower and lower volumes for fear of annoying anyone. It's a concrete building but I can feel the vibrations through the floor when I listen at normal levels. I have tried to dampen it by putting foam in the ports at the bottom of the speaker but it has no affect, I don't know if I'm just not using a dense enough material or if it's just not going to help. Has anyone ever managed to tame low end in a similar speaker?
    As much as it would pain me to do so, I'm considering swapping the Lalis for smaller stand mount speaker that I could enjoy at normal volume. I don't see myself living in a property where the Lalis could do their thing anytime soon. I don't listen to music particularly loud but I am finding it almost too quiet to enjoy now. No point in owning them if I can't appreciate them.
    As always, any suggestions or comments would be much appreciated.
    Cheers
    Rich.
    Clearaudio Emotion with Clearaudio Performer cart
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    Van Damme I/Cs and cables
    yup, its as well to consider those around you as long as its mutual. I made my own to achieve a lower bass output, as im not that keen on it anyway.. but even then the bass does travel even at lower vol. you have solid walls so it should be achievable. maybe some nice full rangers
    Grant .... ؠ
    OPPO BDP-103D - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2 - IFI PURIFIER 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - LEAF HD BLUETOOTH - OPPO PM-3 PLANAR, SONY H900 & NURAPHONE HEADPHONES - ZBOOK/ IFI SILENCER/WIN10 PRO/AUDIRVANA & JRIVER - SMSL M6 DAC & IFI SILENCER - RPI 3+, DIGIONE HAT/VOLUMIO2 - EDINGDALE MK1 SPEAKERS - CABLE INC CHORD, MOGAMI, SUPRA & WIREWORLD
    **Men are not punished for their sins, but by them**Don't be such a big girl's blouse!**
    There is no quick or inexpensive way to reduce low frequency leakage to adjacent properties. Doing so requires extensive structural work and typically the creation of secondary walls or floors. A first step is to talk to your neighbours to establish the extent of the problem and the degree to which the leakage affects them. If it is a significant problem then a change of speakers is probably necessary. Ideally, you will find a speaker that sounds lively at "lowish" listening levels.
    I'm Rich.
    That's my thinking too Grant, my neighbours are a polite and quiet bunch on the whole. The floors are concrete but the walls seem pretty thin. I don't hear anything disturbing from them so I'm keen to do the same.
    I couldn't be happier with how my set up sounds, it's maybe just not right for where I am.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    Do you know if the neighbours have a problem with it? You can feel vibrations in the floor but that doesn't necessarily translate into the neighbours hearing the bass at a level loud enough to be annoying.
    Try some vibration absorbing something under the speakers if you haven't already.
    In any case they live in a block of flats, neighbour noise, including music is to be expected unless it is at unsociable hours. Legally I think that is 0800 to 2300. Personally I don't have music on before 1100 or after 2200 but I think in between is reasonable. Don't forget it's your God-given right as an Englishman to be able to listen to your music.
    *Sony SCD XB790QS* Nelson Pass DCB1 / Krell KSA100 mkII * JM Lab Electra 926 *
    'You fool! To think that your ape-brain could contain the full knowledge of the Krell!'
    I'm Rich.
    It's a rented property, so that rules structural changes out.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    I'm Rich.
    It's never late or early, usually just evenings. It is a good point to make that I should actually speak to them first. I think it's because I had an an obnoxious inconsiderate neighbour a few years ago when in was living in Bristol that keeps me from wanting to be the same without realising I'm doing it. I think what I'll do is put music on at a level I enjoy and pop down to speak to them.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    There is a chance that the reason you don't hear any noise from your neighbours is not because they are quiet, but because the walls/floors are doing a good job insulating the sound. I would agree with Geoff - first step is to have a chat with your neighbours (while playing some music at a level you are happy with), and see what they say.
    I'm sure it can't be as bad as my mum's old house. When I used to visit Friday's, and Bruce's "Play Your Cards Right" came on telly, I could hear the old feller next door shouting "Higher! Higher!....You silly sod, I told you to go higher!" Now that was bad.
    Pining for the fjords? What kind of talk is that? And why did he fall flat on his back the minute I got him home?
    T/T: Inspire Monarch, X200 tonearm, Ortofon 2M Black. Phono: Yaqin MS-22B CD: Densen Beat B400 Plus; Headphone/pre: Myryad Z40; Amp: Audion Silver Night 300b stereo
    Speakers: Zu Omen Def. Atlas Equator interconnects, Atlas Hyper 3.0 speaker cables
    Echo Dot, Amptastic Mini-1, Celestion 5's, BK XLS-200 DF
    Panasonic 42" plasma, Panasonic Blu Ray, Sony a/v amp, MA Radius speakers, REL Storm sub
    I'm Rich.
    That's what the place in Bristol was like, I never heard a peep when a single woman lived next door, she worked in the evenings so we didn't cross at home much. Then one day I heard what sounded like a spoon hitting a bowl from next door, and I thought I must have misheard it as it was crystal clear. But when the quiet neighbour moved moved out and the obnoxious git moved in it turned out the walls were actually that useless, I could hear music, conversation and arguments (and even worse, shagging). I mentioned it politely several times, I even spoke to my landlady about it, but it turns out he was her business partners son so I was f&#ked. I moved out within weeks.
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    Ive someone on one side of me. The walls are fairly poor, but he can be noisy. water pipes and charging up and down stair etc. I dont know why folk cant climb stairs quietly. its not difficult... mind you he is care in the community so its difficult do communicate
    Grant .... ؠ
