Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Deciding on speakers to keep/ comparing - hard work
    I'm Philip.
    Default Deciding on speakers to keep/ comparing - hard work
    Hi
    i have
    upgraded JBL L26
    JBL 4312mk2
    Snell k an-spe silver wired fettled by audionote
    I have been trying to decide which to keep/i prefer this morning.
    Finding it nigh on impossible.
    I like characteristics of all of them.
    It doesn't help that they have different ideal positioning requirements.
    The JBLs on the floor next to each other make them easier to compare, but they are on the floor so bass is altered and comparisons become unreliable.
    The Snells at their best closer to walls.
    Never buy more than 1 set of keeper speakers unless you know you are going to keep all 3.
    It's a recipe for trouble
    I could honestly live with any of them, but which.
    Anyone else had this problem?
    Shame i'm not that close to many other members out here in east midlands, and possibly embarrassed by restrictive listening room
    I think i`d take a vote and be done with it!
    I think i drove my daughter crazy who became as confused as me.
    I'm Adrian.
    What amplifier are you driving them with?
    [FONT="Arial"]
    Listening is the act of aural discrimination and dissemination of sound, and accepting you get it wrong sometimes
    Pro-Ject Signature 10 TT & arm, Benz Micro LP-S & Michel Cusis MC cartridge, Furutech AG-12-R4 High Performance Phono Cable, LFD MMC special phono stage, Rothwell MCX SUT, RaspberryPi/HifiBerry Digi to Beresford Caiman SEG DAC, Sony 3d blu-Ray for CDs to Caiman SEG, ALLNIC T1500 MKII SET 300B amp, Tannoy Legacy Arden speakers and JBL L100 Century's , Chord Epic speaker leads, & signature links, the Eccose Conductor CA1 cd to pre, I think I am at audio nirvana, but donít tell anyone
    Nicer problems to have!
    I suppose it will come down to which type of music you play the most, and which speakers work best with that music. I doubt anyone can give you an informed opinion on this as there are too many variables: room size, musical preferences, synergy, WAF (I know, but it can be important for some of us), and of course your own ears!
    And monetary value doesn't necessarily come into it, you can't assume that more expensive=better. My advice, for what it's worth, would be to keep your favourites, sell the others, then use some of the cash to make your "keepers" even better.
    But what do I know - I spent stupid money on a pair which delight/irritate in equal measure
    Pining for the fjords? What kind of talk is that? And why did he fall flat on his back the minute I got him home?
    T/T: Inspire Monarch, X200 tonearm, Ortofon 2M Black. Phono: Yaqin MS-22B CD: Densen Beat B400 Plus; Headphone/pre: Myryad Z40; Amp: Audion Silver Night 300b stereo
    Speakers: Zu Omen Def. Atlas Equator interconnects, Atlas Hyper 3.0 speaker cables
    Echo Dot, Amptastic Mini-1, Celestion 5's, BK XLS-200 DF
    Panasonic 42" plasma, Panasonic Blu Ray, Sony a/v amp, MA Radius speakers, REL Storm sub
    Sell them all buy better JBLs.
    *Sony SCD XB790QS* Nelson Pass DCB1 / Krell KSA100 mkII * JM Lab Electra 926 *
    'You fool! To think that your ape-brain could contain the full knowledge of the Krell!'
    There you go.
    (or get some Tannoys)
    "when common sense, logic and plausibility are excluded. All that remain are foolishness and lies"
    I'm Philip.
    Marantz pm4 in class a mode.
    Quote Originally Posted by philv View Post
    Should be a good match for all of them. I can see your quandary.
    Location: Bristol, since 1978. Current house since 1996!
    Bigger house? (more rooms....)
    Looking round, I have 5 sets of speakers, -one dormant ; Leak Sandwiches I've had since '72! Others -one set for computer, one for Living Room/TV; one for 'best' underused in basement/hi-fi room; one small set in bedroom. And, no, I'm NOT single!
    Chris.
    I'm Adrian.
    Well the amp is a well respected and quality one which should do any of them justice.
    It's a tricky one with the speakers I used to have a pair of Snell K's and loved them, do you have them on Pirate stands(they weight a ton), I found this improved the bass and soundstage quite a bit, might be worth considering first before getting rid of them. I used to drive mine with an Audio Innovations Series 500 valve amp and these together were very well matched, dynamic and musical. The JBL's are great speakers but I believe will give more low down and if my understanding is right have a bit of a lift around 120hz, probably great for driving rock but maybe not so good for classical and more laid back stuff, but I could be wrong. IMO the Snells are probably the more accurate of the speakers and certainly should be good with all the fettling done.
    An approach I have taken several times is as below, and I found it helps to make some sense of it all.
    If it was me and I was confused I would pick 5-10 tracks that I know very well, make myself a little spread sheet and score each speaker for each track on top, mid, bass, musicality, separation/detail, attack and soundstage, scoring from 1-10 (1 poor, 10 can't be better). I would listen to all the tracks with each speaker and write down a score for each and at the end add them up. I would also make short notes along the way for each track and a summary at the end, so I did not forget my thoughts/feelings about them at the time.
    I would then have a break before moving onto then next pair of speaker so to avoid being influenced by what I had just listened to. Once I had listened to all 3 pairs I would compare notes and decide which was tops and to keep.
    For example tracks I use are, obviously you could just do yours:-
    10cc - Sheet Music, The Worst Band in the World - very dynamic and great separation of instruments
    Alan Parsons - I Robot, I Robot - a classic with lots going one, you will know if it sounds right
    Paul Simon - Graceland, Boy in the Bubble - a great pacey track with lots of drumming, listen out for the backing singers, should be clear
    Sinead O’Connor - I Feel So Different - a very telling track, her vocals are easily mucked up with sibilance if something is not right, you should be able to hear her breathy vocals, the bowed string sections should be clear and there is plenty of bass. The drumming on the following track has loads of attack to check out the speakers.
    Peter Gabriel - Security - Rhythm of the Heat - drumming and bass abounds on this track, his voice should be clear in the mix, and there is a lot of bass extension at the beginning and end.
    Eva Cassidy - Fields of Gold - this is probably one of the most telling vocal tracks I know of, her voice should sound natural and unforced, if sibilance is creeping in it then its not right, listen to her acoustic guitar should sound warm and natural like it is in the room, the electric guitar as some subtle harmonics going on in several places which can be easily lost.
    Ravi Shankar - Portrait of a Genius, Tala Rasa Ranga - all natural instruments, a superb track to check out reproduction of drums, you should be able to clearly hear the two hand drums and how they interplay, the sitar should sit in the middle of the mix with the high ringing drone clear, there is hand percussion which should sound clean and crisp with a ring to it. The flute should sound smooth and natural.
    [FONT="Arial"]
    I'm Philip.
    They all sound great.
    I can live with them all.
    So no desire to upgrade.
    Unless a pair of jbl 4430 come up.....then reason goes out of the window
