Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: Triode or Ultralinear, again
    I'm Shaun.
    Default Triode or Ultralinear, again
    Been listening a lot to my power amp in triode and ultralinear modes just to make my mind up as to which I prefer. Yesterday I was listening to Joshua Redman's 'Freedom In The Groove' from 1996 and started in ultralinear mode. Nice crisp, sharp sound with quite a lot of treble detail and plenty of sparkle. I then switched over to triode mode and it immediately lost a lot of its air and sparkle but sounded a whole lot more real and tangible.
    I am using JJ EL34's at the moment so those familiar with them will know the 'sound' of that valve but, gotta say, love the triode sound for utter realism of that album. Of yeah, still using Spendors by the way.
    The sound is just so dry, close and intimate. Way different to ultralinear. Bring it on..!
    I switch between them depending on the recording, sometimes it's better, sometimes not, still using stock PL valves, I own JJ EL34II's but took them out when I thought one of them was causing issues, didn't make any difference to the issue but I haven't put them back in yet.
    Hi Shaun,
    First of all;
    There are very few Audio tetrode/pentode valves that can be classed as a true triode and therefore those that maintain linearity when connected as one ie; Screen grid strapped to Anode etc, one of which is the KT66, so configuring an amplifier to work on both with most other tetrode/pentodes will almost always compromise on either the tetrode mode, or triode mode, or both!
    In my opinion it is always better to optimise an amplifier for either, not both, however; you can get a good compromise much of the time.
    Again, in my opinion, what your hearing with your amp in triode mode is the mid to high frequencies dropping off much sooner than in pentode mode, also the gain of the amp will change, almost always needing to be turned up to equal the same sound presure level.
    A...
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
    I'm Shaun.
    Anthony you are indeed correct regarding the volume issue. The remainder of what you say I am in no position to comment on. Your knowledge is great against mine. Your comment about the high frequencies though is valid as it does sound as though those frequencies are quite severely rolled off. In ultralinear, the sound is vibrant and full of sparkle but saxophone for example sounds slightly edgy and unreal, however cymbals sound wonderful and the air of the recording is obvious. Vocals also get me in that often a voice has an unnatural edge to it that we simply do not have when we sing in a room but when in triode mode there is no such emphasis. I guess it really is a case of one mode for one sort of music and the other for everything else as stated by mikeyb.
    Hi Shaun, I get where your coming from,
    My point being, if the amp was optimised for one or the other, those issues you describe with either mode could I am sure be mostly eliminated.
    A...
    Nikola Tesla
    Matthew 5:10
    Why make life complicated? How about simply listening to whatever sounds best for each recording??
    PRE
    Because you can get caught up in constantly fiddling around to decide which sounds better and forget to listen to the music. A trap I'm just starting to escape from with all my box swapping in recent years.
    Couldn't agree with you more. I've been selling boxes. I'm happy with my kit. Things in my system haven't changed in years.
    PRE
    Just IME,
    generally triode mode for acoustic/small arrangement/vocal pieces. Certainly sounds closer to how I presume the original recording sounded.
    They sound amazing with acoustic wind and string instruments.
    UL for larger scale dynamic and rock music. Has more slam, bass and sheer "mass" of sound.
    As you have observed, things can get shrill if directly compared with the tracks you've just auditioned in triode mode.
    But, what you lose in delicacy and charm you should gain in dynamics and scale, at least that is my experience.
    As Anthony points out you are unlikely to get to experience the full merits of both until you have an amp designed for one or 'tother.
    I've got a KT88 amp that puts out 35w in triode and around 50w in UL. I reckon it sounds best in triode 80% of the time but given the music I listen to that's not so surprising. Even taking into account what I said above, It's a good amp in general, so actually sounds better than a lot of dedicated triode/UL amps (under say £1000) simply due to being a better design (and slightly upgraded).
    If you're going to "settle" on one or the other I think its horses for courses depending on your majority music preference.
    Happy listening.
    I'm Shaun.
    Chris, damn fine post and very true. I used to have an SE 300B with Audio Note speakers but found I needed two amps. I now have effectively two amps in one box and have been swapping between the two exactly as you have said. Triode mode is so damn sweet with a huge level of realism but ultralinear has loads of energy and punch. Also, ultralinear has a shedload of air and sparkle that really suits the likes of Ozric Tentacles with their everso reverby, atmospheric sound.
    I still think though that my most perfect amp would be a 300B push pull.
    OMG, that 300B sound.
