Results 1 to 10 of 20
Thread: Advice Needed on inexpensive MC Cartridges
    Default Advice Needed on inexpensive MC Cartridges
    Hi All. I have decided to replace my Tangerine LP12 and Naim Aro with something a little more modest
    I have gone for a Voyd TT with an Audio Note Arm 1 V2 and am now somewhat bemused by the amount of MC cartridges
    I have had Linn Asaka, Trioka and currently use a Benz Wood SL
    I am limited to using MC as my Hovland pre only has MC.
    It was quite happy with the Troika's super low output and OK with the Wood's 0.4mv
    I would seek a modest MC with up to 0.5/0.6 mv??? possibly used as I would probably install the Benz Wood when the Lp12 goes
    So any suggestions ??
    Lumley Heliosphere Audiomods 5
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Magnum Dynalab Etude, RWA Cassabria + LCD 3
    Wilson Benesch Actors
    What do you mean by "inexpensive"? What is your budget?
    Probably £2-300
    Hovland HP200 MC
    Hovland Radia
    Ming Da 805 monos
    Audio Technica AT-F2 or AT-F7. I don't know of any other quality MCs at anywhere near the price.
    With that budget you are talking used or second hand. With a little more, there are models from Hana that might interest you.
    That was my thoughts too, low hours mc at that price should just about be doable. Something like a used AT 33PTGII or Denon 103, Goldring Eroica LX.
    I'm Adrian.
    I would agree, I recently tried the Hana SL out on trail in my system, it is a very good musical cartridge IMO. I did see a new one for sale for £599 but cannot remember the dealer, hunt on the net.
    Ortofon MC25FL is another good one to look out for IF you can find one with accurate hours used.
    I thought about suggesting the MC25FL. I have one, bought with only 50 hours on it for about £125. Like the Denon 103, I regard it as a good, 'everyday', cartridge.
    The Goldring Eroica LX is good value and nicely musical. I've had one for years and like it a lot.
