I had a bit of a revelation last night, due to having received a larger Herbies mat to sit on top of my copper mat on the SL-1210. I wanted the larger 295mm diameter to dampen all of its surface, rather than the 285mm version cut for the Techie platter.
Anyway, I was about to readjust the arm's VTA when I thought I'd just take a listen first. The sub-arm on my Dynavector is just slightly nose down and, in this configuration, everything sounded more focused and well positioned in the soundstage and I swear the dynamics were punchier too. Previously I had set VTA with the headshell exactly level and this proves not to create the best sound. The difference is very small, only a degree or two at the most.
So I wondered what VTA setting other AT33PTG users have (and on which arm), and whether you have experimented with different settings?
