Page 1 of 7 123 ... LastLast
Results 1 to 10 of 67
Thread: Passive Preamps
    I'm Bob.
    Default Passive Preamps
    Can anyone offer a recommendation on a passive preamp?
    Ideally it should have 4 inputs plus a tape in / out. It'll also need to be able to accommodate a pass thru although I guess I could just use an input and turn the vol control up to max (right?). A remote control would be useful but I could live without it if there are other benefits.
    I need it to just be audibly invisible. No colouration, neither adding nor taking anything away. This would be going straight into my Musical Fidelity A5cr Power Amp.
    I'd also be grateful to hear from anyone who's tried a passive and found it didn't meet their needs. For what reason?
    Many thanks, Bob
    Source: Orbe SE / SME IV / Cadenza Bronze
    Source: WD NAS / Cyrus Stream X2 / Chord DAVE
    Source: Oppo UDP-205 (CD/DVD-A/SACD)
    Amplification: Icon Audio PS 3 Sig Phono + Audio Research LS27 + Musical Fidelity A5cr Power Amp
    Loudspeakers: ProAc Response D28
    Cables/stands: Mark Grant G1500HD + Linn K20 + Cat 5e
    Other bits: Okki Nokki keeping things clean
    I'm Phil.
    well I am surprised to see a request for a passive after using an arc ls 27 which is on my wish list sometime [ having had a few arc pre amps ] . it would take a very good passive to beat that . also passives with HTB are very very rare . think i saw a MFA once with it
    just for interest the freya has loads of inputs and is incredibly transparent , more so than my pre 3 vbs . its a passive . it would be interesting to compare it to your LS27 . there is one here and not too far from you !!
    https://theartofsound.net/forum/show...assive-pre-amp
    Eric Bibb
    Nelson Pass DCB1 - you'd have to build it yourself or get someone to build it though. Not commercially available as a built unit. But you could specify as many inputs as you wanted plus a pass through. Passive with a buffer so you have to plug it in but there is no gain stage.
    Nelson pass DCB1 is amazingly transparent, depending on the volume control element.
    Just to provide more information this is a potentiometer or stepped attenuator followed by the DCB1 buffer stage.
    Other buffer stages can be used, there are valve based buffer stages available as well, from other vendors.
    A stepped attenuator of sufficient quality will give the best performance, a lot use the Khozmo series attenuator, an alternative that is a little less expensive but of equal transparency is the Acoustic Dimension stepped attenuator.
    Both Khozmo and Acoustic Dimension are available with remote control, though the AD unit is a fair bit cheaper.
    I love my dcb1, its now on it's 6th carnation and each upgrade has been an eye opener.
    It's a very adaptable machine with lots of upgrade paths and a variation of configurations
    Steve..
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    Quote Originally Posted by STD305M View Post
    Steve..
    I'm intrigued by this - is the DCB1 expensive to buy, are they only kit form, and if so how hard are they to make, bearing in mind I have sausage fingers and zero experience with a soldering iron. The idea of getting a pre amp for not too much money, then upgrading as funds become available is quite appealing.
    I'm AndyElectroNumpty.
    Snap! I just did this , see the build thread. With no electronics experiance at all and it has worked out fine . Still running in but certainly showing potential even in stock form. If you are willing to then I would say have a go as there are plenty of people here and on DIY audio who would help out. I sent to board to Alan for a bit of numpty trouble shooting but apart from that was fairly straightforward.
    Sent from my SM-G950F using Tapatalk
    At the cutting edge of Numptyness!
    Hi Steve
    They aren't to bad to build, ive built 6 so far and there are a couple of others on aos who have built them too.
    Price wise somewhere between £460 and £600 depending on spec, fit and finish.
    Regards Steve
    Turntable; Rega p8
    Speakers; Rega Rx3
    Bigman80 Guest
    Yup, best pre I've personally heard and if you invest in it, it gets better and better.
    If you aren't 100% on it, Firebottle is more than capable of putting these together.
    Default Bake off needed
    Is a bake-off needed ?
