Results 1 to 9 of 9
Thread: MM cart advice for technics 1210
    I'm Drew.
    Default MM cart advice for technics 1210
    Hi
    My brother has an unmodded technics 1210 and is looking for a mm cart to better the ‘standard’ Stanton. Is there anything around the £100 mark that could offer improvement? Thanks!
    I'm Mick.
    Ortofon 2m carts always do well on Technics standard arm. You may get a 2m blue for his budget that sounds pretty good.
    Technics SL1210 MK2 fully rebuilt and repainted. Ortofon 2M Black Cart, Isonoe isolation feet , MN bearing and Funk Firm platter upgrade, Oyaide RCA Tone Arm and speaker cables, Jelco SA-750D Tonearm. Oyaide HS-TF Carbon headshell, MCRU Linear External PSU, High Fidelity Crystal glass turntable matt, Blue LED upgrade, Denon AVR-2808CI Amp, Bowers and Wilkins DM602S3 Speakers,
    Black Rhodium Jazz power cables for amp and turntable, Firebottle mk2 Phono Stage.
    I'm Drew.
    Thanks! Will try to find one... any others?
    The Nagaoka MP 11 is a good cart for a standard Techie
    I had a 2m Blue on mine for a while, was decent for the money, a bit hard edged when pushed loud on rock but if you can pick one up second hand it's a decent buy.
    Nagaoka MP110.
    Chris
    Shure M55e + JICO stylus.
    PRE
    I'm Hugo.
    For up to and around £100 you'd be mad not to consider the new Audio Technica AT-VM95 range - see https://eu.audio-technica.com/cartridges/moving-magnet
    I'm malcolm.
    +1
    I'm using a VM95ML, about £150, and am very impressed with it.
    Audiophile Tosher
