Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: EPOS ES11 Hi-Fi speakers
    Default EPOS ES11 Hi-Fi speakers
    Boxed, with manual Bi-Wired British Audiophile Loudspeakers in black ash.
    These are hi end, Hi-Fi speakers. The ES11 are an early 1990s British design and very simply they sound incredible. They have a very full, neutral sound with a smooth low end, sweet top end (never harsh) and a detailed mid-range. Perhaps the best feature is the wide stereo imaging they offer, which is simply stunning. They come with full size hard plastic covers which slot on the front to protect the drivers, the original packaging & box. These sound best when placed on open speaker stands, I have some for sale if needed.
    Independent reviews can be see here: https://audiophillness.com/epos-es11-sn15151/
    Specification
    • extremely rigid cabinets due to their extraordinary construction, completely resonant-free;
    • front baffle and rear panel made out of hard plastic;
    • mid-low woofer with a fixed phase plug and rubber surroundings;
    • Naim NACA5 wiring inside;
    • 25mm MDF enclosure covered with natural veneer;
    • bi-amping capable;
    • easy to place in the listening room – just put them on rigid stands at least 50cm from side walls and 20cm from the back wall.
    • Power Handling: 75 Watts speech and music.
    • Impedance: 8 ohms Nominal
    • Dimensions: 375mm (H) x 200mm(W) x 250mm(D)
    • Weight: 8kg
    Priced at £250, prefer collection but will send by courier at buyers expense.
    I live in Redditch, Worcestershire, and I'm hoping I've inserted the photos correctly.
    I'm Phil.
    can`t see the pics sadly mike
    Eric Bibb
    I'm Alex.
    I can
    I'm jamie.
    i can see them too.
    My System
    John Wood KT88 Amp.
    Paradise Phono Stage
    Sony TTS-8000 Turntable.
    PMAT-1010 MK6 Tonearm.
    Ortofon Cadenza Bronze
    Sony X555ES Cd Player
    Yamaha NS1000m Speakers
    I'm Deleted.
    I can’t see the pics so I guess it is a Safari issue.
    Account Deleted
    I'm Rich.
    I can't see them either, I'm on Firefox for windows.
    Clearaudio Emotion with Clearaudio Performer cart
    Copland CDA 266
    Copland CSA 28
    Squeezebox Touch
    Impulse Lali
    Van Damme I/Cs and cables
    I'm Paul.
    Nor can I and I'm using Chrome
    Linn Sondek LP12, Ittok, AT-F7
    Schiit Mani MK1 Phono Pre-Amp
    Nobsound NS-08P Bluetooth pre-amp
    Marantz CD5004 CD Player
    Pure DAB tuner
    2 x Meridian 205 monoblock power amps
    Tannoy T225 "Mayfair" speakers
    www.paulridgeblog.com
    I'm jamie.
    Quote Originally Posted by stairpost View Post
    same as me but i can see them??
    My System
    John Wood KT88 Amp.
    Can't see them
    Thanks guys, I'm not sure what to do here as some can see the pics but others can't. I can send them on email if anybody wants me to.
