Results 1 to 9 of 9
Thread: Marantz 6006 issue
    I'm Colin.
    Default Marantz 6006 issue
    Hopefully this is in the correct section. Just set up new marantz cd6006. All appears ok and performs well but remote control seems to be completely inoperable? Am I missing someone obvious , I can’t fin£ any info online about issues so thought I would try here.
    Any thoughts?
    Colin
    I'm John.
    Have you made sure the batteries in the remote are okay and inserted correctly?
    Sent by me using an appendage
    SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
    Luxman 509X amp.
    PMC 25 23i speakers.
    Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
    Cables by Kimber, Yannis and Audioquest.
    Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
    I'm Colin.
    Yes first thing I did and even put new ones in but I will try another set just in case
    Colin
    Sometimes new remotes have a protective film over the end that needs to be removed? Have you pressed the 'remote mode CD' button?
    I'm Colin.
    Nope tried that as well?
    Is it brand new Colin?
    I'm Colin.
    It is and it is now sorted. On the back is an internal /eternal setting which doesn't really get highlighted in manual. now fully functioning. thanks for input.
    Colin
    Quote Originally Posted by Colin2040 View Post
    Colin
    Hurrah
    I'm Colin.
    thing is I never read instructions.....this time I did and it didn't help but thought it would be something obvious and I must admit its playing t=rather nicely now.
    Colin
