Results 1 to 6 of 6
Thread: FS: A couple of platter
    Default FS: A couple of platter
    These platter mats are excess. Firstly the excellent Oscars Gimp mat. This is a 3mm Neoprene mat which works extremely well if you want to add a little more isolation to your platter. I used this particular mat for 2 years whilst experimenting with my Lenco 75 project. Eventually I settled up a SPH mat, hence why this is excess to needs. This mat is extremely light weight and would be ideal for those of you with spring suspension turntables like the LP12 or the Thorens TD150/160 etc decks.
    NOW SOLD STP!
    The next mat is 5mm of pure rubber lovely thickness originally from a Lenco GL75 and its missing the silver central disc. This mat was again used extensively during my experimental phase with the Lenco project. The central metal disc dosen't really seem to do too much and I never used it during my experimentation. The mat is heavier than the Gimp mat but works equally well with idlers and spring suspension turntables. I have cleaned this mat with Autoglym and it looks fresh. Again its priced to sell I'm pricing this to sell at £10 delivered. .
    Thanks for looking
    A.
    PRE
    I'm Adam.
    I’m pretty sure mat number two is actually a Goldring Lenco mat. I’d say it’s from a GL 75 but is missing its centre silver trim disc.
    Yup.
    I'm malcolm.
    Quote Originally Posted by Beobloke View Post
    +1
    Audiophile Tosher
    I'm Norman.
    Hi Andrew,
    I'll take the Gimp mat if still available. PM your details if this is the case
    Regards Norman
    Guys I stand corrected, just had a little look around on't net and you are all correct. SO MANY THANKS! ADVERT NOW CORRECTED
    Norman, I've sent you a PM
    PRE
