Page 15 of 16 FirstFirst ... 513141516 LastLast
Results 141 to 150 of 153
Thread: SPOTFIRE speaker cable
  1. #141
    I'm Oliver.
    If you could measure how much cable is needed to get vertical from horizontal with plugs it will let me know for sure.
    How high are the terminals on the speakers?
    Analogue: Technics SP10 MK2 > Phonomac AT-1010 MK6 tonearm > Ortofon Kontrapunkt b > Bigbottle Jfet MC Valve Phonostage (Telefunken Valves)
    Digital: Raspberry Pi 3+/Allo Boss 1.2/Isolator 1.3 & 2x LPSU's with Volumio & JRiver
    Amplification: Nelson Pass DCB1 with Khozmo 48 Step Series Attenuator & Krell KSA100 MK2 Amplifier
    Cables: SPOTFIRE Speaker Cable & SPOTFIRE IC Cables & SPOTFIRE Tonearm cable
    Speakers: Pioneer CS-77A
    Price List For SPOTFIRE Cables here:https://bit.ly/2Uxiv3j
    Alternative reading: http://www.audioaddictsforum.com
  2. #142
    I'm Oliver.
    So, a 10cm gap allows for the use of bananas
    As you can see, the cable is significantly thicker than the SPOTFIRE Interconnect!
  3. #143
    They are halfway up. Bottom of speaker socket to top amp socket is 65cm maybe slightly less. Leaves 35cm for 2 bends. so as long as the bend doesn't make them stick out a foot a meter might do. I don't like spades
    Grant .... ؠ
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2 - IFI PURIFIER 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - LEAF HD BLUETOOTH - OPPO PM-3 PLANAR, SONY H900 & NURAPHONE HEADPHONES - ZBOOK/ IFI SILENCER/WIN10 PRO/AUDIRVANA 3 PLUS/TIDAL - SMSL M6 DAC & IFI SILENCER - RPI 3+, DIGIONE HAT/VOLUMIO2 - FULL RANGE TWIN TELEFUNKEN SPEAKERS - CABLE INC CHORD, MOGAMI, SUPRA & WIREWORLD
    **Men are not punished for their sins, but by them**
    I'm Oliver.
    Ok, understood.
  5. #145
    Had a longer listen with these speaker cables in place now and am pleasantly impressed. Had some incompatibility between DCB1 pre and the XTZ so am now using the XTZ as an integrated which is a surprising improvement. That aside I can now hear that the cables really do deliver the subtle resolution required to make those little things that are so important work - like getting cymbals to ring and decay just right. The sound is very precise and 'tidy' (can't think of a better word right now). Bass resolution is excellent.
    Only drawback is that with their huge girth and fancy braided covers it does make it look like I've spent thousands on audiophile speaker cables which is a bit embarrassing. Fortunately I don't get many visitors.
    If you can live with that shame I highly recommend checking these cables out.
    Martin
    Technics SLP1200 CD Player * Nelson Pass DCB1 Pre amp / Krell KSA50S Power amp * JM Lab Electra 926 loudspeakers *
    'You fool! To think that your ape-brain could contain the full knowledge of the Krell!'
  6. #146
    I'm Oliver.
    Oh the shame!!!
    That made me laugh Martin.
    Yes, they may "look" fancy but it's all about the sound. It does take a few days to get your brain around the sound and as you say, when starting from a position of having decent speaker cables, the subtle differences take a bit longer to register. That's been a common statement since I started selling them but everyone has confirmed my opinion of these cables, which is all I can ask.
    I started from a position of bang average and the improvement blew me away. I'm still enchanted by the sound I get. I'm hoping you get the Krell back up and running soon, as the combination of DCB1>Krell will really demonstrate their ability.
    Thank you for the update and I'm really pleased they are working for you.
  7. #147
    I'm Oliver.
    Another set under construction!
    5m this one! Longest one yet and it's like wrestling a Boa!
  8. #148
    I'm Justin.
    Imagine the bi-wire version - a large octopus?
    Need to find an excuse for a quad wire.
    How you did a selfie 30 years ago....
  9. #149
    I'm Oliver.
    Quote Originally Posted by User211 View Post
    yes indeed!. I did make a Bi-wire pair recently? Can't find the pic.
  10. #150
    I'm Oliver.
    Finished!
