Results 1 to 6 of 6
Thread: Amp upgrade
    Question Amp upgrade
    Help I think have fallen down the rabbit hole and I can't see the bottom! I'm looking at upgrading the amp in my current setup:
    Cambridge Audio One
    Cambridge Audio Minx XL Speakers
    Onkyo SKW-409 subwoofer
    I'm looking at the Rotel A14 Integrated Amp. However one thing I can't figure out is how I'd connect the subwoofer. I have RTFM and still can't figure out how I'd connect the subwoofer.
    I'd appreciate some enlightenment from someone who knows more than I do about how I'd go about connecting a sub to the A14.
    Hi James
    I'm pretty sure you have pre out on the Ra14, just connect to that.
    Thats assuming you have an rca connection on the back of the sub ???
    Steve.
    Turntable; Rega p8
    Cartridge; Alpheta mc
    Amplifier; Rega Elicit
    Speakers; Rega Rx3
    The Rotel does have RCA pre-out sockets. Don't know about the sub but it would be pretty weird if it did not have RCA line in sockets. Just connect the two and you're cooking on gas.
    I'm Adrian.
    As Martin says you have RCA out and looking at various Onkyo subwoofer manuals they have one input to connect to and then volume adjustment, I cannot find a specific manual for the Onkyo SKW-409 subwoofer. Take a picture of the rear of it and put up here.
    Thanks Steve, Martin, and Adrian!
    Here is the back side:
    https://imgur.com/jgr14zq
    Pretty basic.
    So:
    Sub > Pre Out (either L or R, I'm assuming it doesn't matter which) with the RCA cable.
    Easy.
    That's all there is to it.
