CDM4 Transport Tweak
I have a CD50 marantz and a CD52 both with CDM4 transports.
I had some mistracking with my much loved CD52 this evening and fixed it with a flat blade screwdriver end and 4 tabs of sunflower oil
to the screwdriver tip, to then very very lightly lubricate the central metal bearing which interfaces with the plastic upper section. No mistracking following
I dont think I'd use sunflower oil which will coagulate over time. Special plastic grease SPG is what you need for lubing this type of thing
Sent from my ONEPLUS A5000 using Tapatalk
Thanks for your reply. As I google search the subject coagulation requires addition of other liquid, which is not the case here.
rather the articles that I am reading seem to highly recommend sunflower oil for its superior lubricating ability.
When or if it subsequently fails I will write back - which might be many years from now.
coagulateDictionary result for coagulate
/kəʊˈaɡjʊleɪt/Submit
verb
(of a fluid, especially blood) change to a solid or semi-solid state.
"blood had coagulated round the edges of the gash"
synonyms: congeal, clot, cake, solidify, thicken, harden, gel, curdle, stiffen, set, dry; rareinspissate
"the heat causes the blood to coagulate"
cause (a fluid) to change to a solid or semi-solid state.
"adrenaline coagulates the blood"
There's no other fluid involved in coagulation. just look around the neck of a bottle of sunflower oil that's been opened and left at room temp for a few months.......
- You may not post replies
- You may not edit your posts
Forum Rules
