I think your suggestion of Quad amplification is likely to be good here. An Artera or QSP power amp with a passive pre-amp should drive those speakers without any bother. The Quads are are good value too for the power and build quality on offer.
You could even consider a second hand 909, 707 or 606/II, they are very similar in design, power and sound quality.
The Quad sound is relaxed and clean with plenty of detail, bags of power too.
