Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Room Dynamics and the Effect of Hard Surfaces
    I'm Paul.
    Default Room Dynamics and the Effect of Hard Surfaces
    My listening position has my head about 8in away from a rear stud wall, he puts me to shame tbh
    Would I see any benefit making that wall as sound deadening as possible with say some acoustic tiles / matting?
    I can position myself equidistant to my speakers (around 8 foot with a slight toe-in) and the speakers are about the same distance apart from each other with a big telly splitting the two. I'm currently considering putting a big heavy blanket over the telly to prevent unwanted deflections but am I taking it a step too far with the wall? My floor is carpeted and I have heavy curtains behind my system.
    Has anyone seen any improvements softening walls / floors / windows?
    Current system:
    RPi + Allo Digione
    Beresford Caiman Seg & Dorado powered by 15v Linear PSU
    Transcendent Sound Mini Beast OTL
    Amptastic Mini-1
    Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
    110aH Leisure Battery powers the Mini-1 & Digione
    Quote Originally Posted by Pepperamip View Post
    I use Magneplanar speakers in a dedicated music room: a double bedroom. The room is a decent size but smaller than the rooms I am used to running Maggies in. I made a number of acoustic panels out of 100mm acoustic Rockwool insulation. One set is positioned behind the speakers. The other (smaller panels) are behind my listening chair at ear level. Together they provide just the right amount of "damping" to tame early reflections and smearing from back wall reflections.
    Geoff
    Yes. I have a big window right behind me, closing the (quite thick) curtains makes the sound improve noticeably.
    I'm paul.
    IN my dedicated room I have 4' x 2' x 2" panels behind my sofa, two upright and the third across the top of the other two. Top one angles away from the wall and touches the ceiling as the ceiling is low. Also have another 4' x 2' x 2" panel at first reflection by right speaker and another on the ceiling. The left speaker is by French doors with kilo serge wool curtains as used in vocal booths.
    If you can manage it, ideally the speakers should be placed at a 'live' end of the room (i.e. an end with a large window or patio doors) and the listening position at a 'dead' end of the room (if that too has a window - close the curtains).
    I'm inactive.
    Always found the bay window syndrome a problem with typical UK semis - and try to avoid setting up speakers on either side or facing them unless heavy drapes are to hand.
    Years ago I worked for a firm who hired out heavy velvet curtains to venues for sound deadening purposes.
    Biggest customers were modern conference centres with big glass areas to cover. They made a massive difference
    I'm Mark.
    I had glass bookcase doors right behind me. Covering them with cork tiles (looks far less gash than it sounds) made a huge difference
    I'm Paul.
    Barry ive managed this to some extent where my speakers face out from a top to floor window but then i have patio doors just in front of my right side speaker (perpendicular) However the cuetains are always closed covering these by the time im listening to music.
    I do have a big 1m squate painting behind my head too so i wonder if that does parrt of the job for me.
    Sent from my SM-G930F using Tapatalk
    Current system:
    RPi + Allo Digione
    Amptastic Mini-1
    This also relates to the recent suggestion of trying different speaker positions to improve the sound from the speakers. Most of us don't have enough control over our rooms to be able to really judge. One room we have is a quite large conservatory - not good in terms of reflecting glass. However, on one occasion I was presenting an evening of recorded music to a society, so decided to try in that area. Because the space was relatively free from other furniture I was able to position the speakers quite carefully. Small differences in position did make significant differences to the spatial characteristics of recordings.
    My suspicion afterwards that "ideal" listening rooms would have hardly any furniture, and be acoustically dead - so that any ambience from the recording could be picked up, yet such rooms would probably be horrible to live in. Also it may be that recording engineers and producers actually do expect users to listen in "normal" rooms, so don't actually mix in any additional reverberation. Listening to some recordings in a completely dead sound environment might actually be unpleasant, unless artificial reverb is added in within the listening environment.
    Only a very small amount of artificial reverb would be needed, but it could make some recordings more enjoyable to listen to. I don't think many of us are shaping the sound within listenning rooms in that way, though.
    Getting listening right for more people presents additional problems too.
    Dave
    My understanding is that the reflected high frequency sounds need to arrive at your ears shortly after the direct sound, too much of a delay and you get smearing and muddle. But if there are no reflected HF sounds at all it will sound dead with very little soundstage. So treating a room is a complex undertaking as you need to get into the goldilocks zone.
