Page 33 of 95 FirstFirst ... 2331323334354383 ... LastLast
Results 321 to 330 of 944
Thread: Bigblog - The Revolving Door of HiFi Auditioning
  1. #321
    I'm Oliver.
    Perhaps you could work in some heat sink? I am not fond of the idea of using fans. Even the most silent fans get clogged up with dust, and their bearings wear and wobble. So over time they become a liability.
    Or, if tubes are involved, massive ventilation, lots of slots for air to circulate? Instead of a plexiglass top, a wire mesh top?
    Russell
    Adding some heat sink is a good shout. I do like fans though. I'll weigh up the pros and Cons
  2. #322
    I'm Russell.
    Fans are very effective. Just figure on replacing them every few years. Depending on the location, and how much dust is in the air. Think of your ceiling fans, how much dust do you knock off of them every time you clean them? I clean mine probably every 6 months, and the dust is horrible! I worked on computers, and Iíve seen those little fans clogged slam up, causing computers to overheat, and rattle and hum. I recall a computer out in a warehouse office, and when I pulled the cover, the dust was the shape of the cover! A big square block of dust bunnies! I know your home is cleaner than that, but fans do work! They just require maintenance.
    Russell
  3. #323
    I'm Oliver.
    Yes, I totally agree with you there. Maintenance is key
    I'd probably just Bung a 1" fan there, to circulate the air inside.
    In through the vents out through the fan.
  4. #324
    Hi Oliver
    I have 45mm silent fan here, I'll bring it up tomorrow if i remember
    Steve
    Garrard 401
    Acos Lustre gst-1
    At-oc9
    Bigbottle bb3 phono stage
    CXN-V2
    Audiolab M-pwr
    Monitor Audio Silver
  5. #325
    I'm Oliver.
    No worries mate, thanks!
  6. #326
    You want massive heatsinks not fans. All serious gear has massive heatsinks. That's not happened by chance.
    *Oppo BDT-101CI* Nelson Pass DCB1 / Krell KSA100 mkII * JM Lab Electra 926 *
    'You fool! To think that your ape-brain could contain the full knowledge of the Krell!'
  7. #327
    I'm Oliver.
    Trouble is with massive heat sinks, they're massive lol
  8. #328
    Nowt wrong with massive. People these days seem to have massive fridge freezers. Was at a place the other night and the thing was so big it took up a quarter of the kitchen. Ice dispenser built in though, which is classy.
    But seems to me if you can have a massive fridge freezer taking up all that space even a really big amp is nothing by comparison.
  9. #329
    I'm Oliver.
    Haha, I like the reasoning
  10. #330
    Default Bigblog - The Revolving Door of HiFi Auditioning
    Yeah, but how did it sound? A bit stark and lacking warmth I bet?
