Results 1 to 8 of 8
Thread: FS: Chord Odyssey 2 Speaker Cables - 5m pair.
    Bigman80 Guest
    Default FS: Chord Odyssey 2 Speaker Cables - 5m pair.
    After hearing the effect the Chord Epic had in my system, i decided to try a few items from the Chord range and check out the competition
    Here we have a 5m pair in good, not quite perfect condition. A little nibble on the heatshrink is visible on one plug but other than that, they're good! Complete with matching jumper cables.
    Here's the Marketing blurb:
    Chord Odyssey 2
    The Chord Odyssey is a very similar design to Chord Rumour but features larger conductors. This brings real improvements to the dynamics of sound and music, particularly in the bass. Cymbals are shimmeringly realistic, acoustic guitars and pianos have natural weight and realism.
    The Chord Odyssey speaker cable is almost identical to Rumour. It features 19 strands of silver plated oxygen free copper per conductor surrounded by Teflon insulation and twisted together; the major difference being the overall gauge of the conductors. Whereas Rumour uses 16 gauge conductors, Chord Odyssey has altogether more substantial 12 gauge conductors and will carry significantly higher currents. Chord Odyssey is available in a two (Odyssey 2) and four core (Odyssey 4) version.
    Like Rumour, The Chord Odyssey is extremely compatible and is used across a wide range of systems. Because of its compact construction, Odyssey is a great favourite with people installing high-end audio and home cinema systems. As a point of interest, for reasons of cost, people who need extremely long runs of speaker cable tend to fit cheaper cables because of the cost involved. Better quality cables can really come into their own when the lengths required are longer than average.
    The Chord Odyssey brings real improvements to the dynamics of the sound, particularly in the bass, both in terms of weight and attack. This is also true of the mid and treble as well. Cymbals are noticeably more realistic and have greater weight and authority. The same is true of acoustic guitars and also pianos. The lower resistance of the Chord Odyssey also makes it a particularly good choice for longer runs.
    Heavy gauge silver-plated oxygen free copper conductors
    Twisted pair configuration
    Teflon insulation
    Silicon outer jacket provides outstanding mechanical vibration damping
    Priced to sell:
    £185 Delivered
    £175 Collected
    Very close offers on these will be considered, at £100 less than new, the price is VERY competitive.
    Bigman80 Guest
    Can a mod change the title to "Chord odyssey 2" please. Then delete this post, ta!
    Bigman80 Guest
    Bump
    Sent from my KFFOWI using Tapatalk
    Bigman80 Guest
    Weekend drop to
    £160 delivered
    £150 collected.
    Bigman80 Guest
    Bump
    Bigman80 Guest
    Bump
    Bigman80 Guest
    Still here!
    Very surprised TBH.
    Bigman80 Guest
    Still here,!
