Anyone near Brighton that can do this please ?
My System
John Wood KT88 Amp.
Paradise Phono Stage
Sony TTS-8000 Turntable.
PMAT-1010 MK6 Tonearm.
Ortofon Cadenza Bronze
Sony X555ES Cd Player
Yamaha NS1000m Speakers
Might be helpful to say what amplifier.
You might be able to learn how to do it yourself, are there accessible controls and test points?
Hi Alan,it’s a kt88 as in my sig, John wood told me the bias is set at 30 me but I can’t for the life of me remember where he showed me to put the meter probes, I know roughly, I’ve emailed him to ask but thought I’d see here as well. I will post a close up pic later if that helps.
I’d like to check the bias because I seem to have a slight drop in gain and after he adjusted the bias last time it sounded great, the power valves according to him were about 63% but I wonder if some new ones might help?
My System
John Wood KT88 Amp.
I should add it’s a fixed bias and it’s adjusted by a small screwdriver .
My System
John Wood KT88 Amp.
The little blue 'trimpot' is where the adjustment is made, as you say.
I am assuming there is just one adjustment as you have said it is fixed bias, as opposed to individual bias adjustments for each valve.
The only drawback with fixed bias is that as the valves age they can become unbalanced, that is have different conduction.
Each valve has the blue adjustment pot, it’s knowing where to put the red and black bolt meter probs that I’m unsure about.i will post a better pic when I get home, I’m aware of the huge voltages hence why I’d like some advice first
My System
John Wood KT88 Amp.
here's a better photo,
and close up.
My System
John Wood KT88 Amp.
I'm Mick.
Typically you measure the millivolts across the resistor, this gives the current in the circuit.
thanks,you mean the brown one or the blue one just behind the capacitor?
My System
John Wood KT88 Amp.
Second photo shows the sense resistor. It is 1 ohm, Brown, Black, Gold, Gold.
Connect the meter across each of these in turn and adjust the respective trimpot.
For 30mA you will measure 30mV (millivolt) on the most sensitive voltage range on the meter.
Job done
