Results 1 to 10 of 17
Thread: Ethernet cables
    Default Ethernet cables
    Anyone recommend an Ethernet cable supplier - thanks.
    VPI Scout 1.1 - Ortofon 2M Black FGS - Croft 25R+ - Croft Series 7 - Spendor SP2
    Last one i got was a Duronic WE 10m Network Cable CAT6a Ethernet LAN Patch Cat 6 A RJ45 Wire Gigabit FTP Gold Headed Shielded - High Speed 600MHz .... nice quality... amazon supplied it.https://www.amazon.co.uk/gp/product/...?ie=UTF8&psc=1
    Grant ....
    OPPO BDP-103D DARBEE - JBE SERIES 3/B&O SP1/PROJECT PHONOBOX DS2 USB - QUAD VENA 2/TWIN PRO MONOBLOCK POWER AMPLIFIERS - XS VALVE DAC - AVANTREE OASIS PLUS + LEAF HD BLUETOOTHS - OPPO PM-3 PLANAR +NURAPHONE HEADPHONES - ZBOOK/WIN10 PRO/AUDIRVANA 3 PLUS/TIDAL - SMSL M6 MINIDAC - RPI 3 DIGIONE/VOLUMIO - FULL RANGE TWIN TELEFUNKEN MAIN SPKRS/Q ACOUSTIC BT3 ACTIVES & CANTON SUB - P.INSPIRED MAINS REGENERATED.
    **Men are not punished for their sins, but by them**
    I'm Gary.
    Remember to maintain the Cat status performance the minimum bend radius should be maintained
    Gary
    James,
    That looks like very nice cable.
    I have been using CAT 7 because it is supposed to be better shielded , each wire in its own mylar jacket ,less cross talk and better RFI rejection .
    What I have found is early CAT 7 can be 27 awg and newer is 26 awg. as there is no regulation or cable standards for CAT 7 for the telecommunications industry and no official specs so buyer beware ,It is supposed to support up to 600mhz. Is it any better than your CAT 6A probably not and doesn't matter,it's fast enough for my sons gaming computer.
    CAT 8 coming soon!
    https://planetechusa.com/blog/ethern...-cat7-vs-cat8/
    This looks good. https://www.amazon.com/Ethernet-Shin...CQ7622EYXKK18P
    Jeff :UBERTHREADKILLER
    I'm AMusicFanNotAnAudiophile.
    Quote Originally Posted by goraman View Post
    Shielding means diddly if it isn't properly referenced to ground!
    If it ain't properly referenced to ground it's called an aerial.
    It needs to be referenced to your CMET.
    What you need to create is a Faraday Shield, and without an appropriate ground connection you do not make one.
    Chris
    Common sense isn't anymore!
    Chris ,
    Sorry but shielding dose NOT have to be shunted to ground to be effective.
    Shielding can work with no connection to anything what so ever.
    I learned this in Armature radio years ago , and mylar can be very effective at rejecting RF .
    In fact so can a well placed Ferrite RF choke that is also ungrounded.
    In the case of mylar it simply reflects RF away from the signal wire, think of it as a physical barrier like a brick wall .
    Chris ,
    If you look at the Cat6A and Cat7 spec, you'll see that it's an integral part of the spec.
    Chris
    I am not saying it isn't grounded , I am just saying mylar can be used as a shield with no ground.
    I'd be much more concerned about the induced RFI from the SMPS that power network devices, to be honest.
    Chris
