Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: MC cartridge loading
    Bigman80 Guest
    It's easy if you have a calculator;
    Loading resistor value = Desired value/(1 - (desired value/1000)).
    Thus in David's case, for example, if the desired value is 250 Ohms, the loading resistor placed in parallel with the head amp is
    250/(1 - 250/1000) = 250/0.75 = 333 Ohm. (The nearest preferred value is 330Ohm)
    Ah, excellent. Thanks Barry.
    That equation was specific to David's case of his head amp presenting a load of 1000 Ohm.
    In general the formula for two resistors, R1 and R2 in parallel is:
    R1*R2/(R1 + R2)
    So if R1 is the impedance of the head amp (call it Rh) and Rc is the value you want the cartridge to 'see', then the value of the additional loading resistor (RL), wired in parallel with the head amp (or SUT) is
    RL = Rc/(1 - Rc/Rh).
    Maths lesson over for today!
    Bigman80 Guest
    R1*R2/(R1 + R2)
    Thanks mate. I'll try it out.
    Bigman80 Guest
    Ok, so using your equation, my phonostage presents 1k so for the desired 470R loading I like I'd need 626R
    Have I done that right?
    No, the value should be 887 Ohm:
    470/(1 - 470/1000) = 470/0.53 = 886.8 Ohm.
    Bigman80 Guest
    I know if got it wrong. I'm am awful at math. Seriously bad.
    i got it right
    Bigman80 Guest
    honestly, I have that numerical dyslexia I think. I should get checked out.
    I'm John.
    I'd sell the Ayre!
    try 2000 amp and 300 desired
