Results 1 to 4 of 4
Thread: 15" Monitor Red External Crossovers by Reference Fidelity Components
    I'm Clive.
    Default 15" Monitor Red External Crossovers by Reference Fidelity Components
    A beautiful pair of external crossovers for Tannoy 15" Monitor Reds built by Paul Coupe at Reference Fidelity Components.
    Details of Paul's build and pictures can be seen on this thread here, post numbers 926 to 927.
    https://theartofsound.net/forum/show...red+crossovers
    Full Specification:
    External crossovers for 15 inch Tannoy Monitor Red 15 drive units;
    Oak veneered sides with smoked acrylic tops, A4 in plan size by about 110mm height,
    equipped with rubber feet, captive input and output leads (on same end) and oil finished to
    fine furniture standards with a final wax buff;
    Input to be a 0.5m captive OFC 2 core copper cable, terminated with 4mm banana plugs.
    Output to be 2.0m captive OFC 2 core copper cable terminated with a 90 degree XLR plug
    Circuit topography to be as per RFC’s “Reference” standard crossover with discrete signal
    and ground rails for LF/HF built onto solder tag boards, point to point wired
    Components to include high quality Mundorf capacitors in the signal path, high quality
    Pathaudio resistors within HF signal path, custom wound Janzten Air Cored low distortion
    low DCR bass inductors; Jantzen air cored HF notch filter inductors, Claritycap LF capacitors
    and solid enamelled copper rails.
    Whilst this crossover has been designed to closely mimic the factory crossovers, it improves on the factory supplied crossovers by introducing a discrete topology for reduced crosstalk/noise plus uses higher quality audio grade components built on high quality point to point copper rails. Importantly, it also introduces something the factory ought to have done by providing a switchable notch filter targeting the area of increased HF distortion and a spike in response at just over 3 Khz.
    Price £600 plus postage.
    I presume the crossover for 15” monitor golds would be a different build?
    I'm Clive.
    Quote Originally Posted by Mike S View Post
    Yes, very different and more complex.
    I'm Clive.
    Now SOLD
