Ok...i didn’t do this in tne end.
However, another noddy question, just to be sure.
I’m refoaming woofers using a 30mhz test signal.
Instructions say to wite up woofer directly to amp. Ie no crossover.
I only want to do one at a time slowly.
Am i ok to only have one woofer connected to tne amp?
Ie no cable connected to other channel from amp?
It’s only low volume 30mhz.
I’m using a marantz pm4.
Thanks
I think and hope you mean 30 hz, There is no need for a test tone to be running at the same time.
Conventional crossover design usually includes at a minimum a inductor in series to the positive of the woofer
and the negative grounded. See the linked schematic for a gale GS401 using 2x 8 inch woofers in parallel
http://0339436.netsolhost.com/WordPress/gs401-speaker/
- You may not post replies
- You may not edit your posts
Forum Rules
