Results 1 to 10 of 17
Thread: Advice on Passive Pre-amp
    Default Advice on Passive Pre-amp
    Hi all. I thought I would try a passive pre as my TT does not get any use.
    Totally puzzled on how I determine the log value needed
    Any ideas??
    Tangerine LP12,Naim Aro, Benz Wood
    Hovland HP100 MC
    SiriuS D100
    Quad FM4,RWA Cassabria + LCD 3
    Wilson Benesch Actors
    HSM with re capped Mundorf Supreme and Atlas rewire
    SS amps generally have lower input impedances, perhaps 22K or 10K on some.
    Valve amps generally have higher input impedances, perhaps 100K or even going as high as 1M.
    I usually opt for something in the middle that will work with either, so 50K for me.
    Thanks Alan, the Sirius is 10k so it should be OK
    Hovland HP100 MC
    SiriuS D100
    I'm Phil.
    I have the marvellous freya passive which seems excellent. Be happy to pop round one day and try in your system
    1]bel canto pre 3 vbs /MSB s200 , / onkyo sacd/ bel canto fm1
    sonos, . tannoy eaton legacy 2]schiit freya pre , firebottle mono`s marantz sa8005 bel canto 3.5vbss and RFC impulse ta`us , track audio stands 3] harbeth p3esr /rotel
    Quote Originally Posted by hifinutt View Post
    That sounds like a good idea. I have a Khozmo arriving at some time???? so would be ideal then
    Hovland HP100 MC
    SiriuS D100
    I'm Phil.
    Excellent , nearly got a khozmo recently but not enough inputs . The freya has loads and several for too. Let me know when arrives and we can compare
    I'm Paul.
    Phil, I'm having a BTE Designs preamp made up with a Khozmo stepped attenuator and you can have as many inputs and outputs as you wish.
    Current system:
    RPi Allo Digione
    Minix android box (portable HDD with FLACs)
    Beresford Caiman Seg powered by 15v Linear PSU
    Tisbury Passive Preamp
    Quad 306 upgraded
    Amptastic Mini-1 powered by 12v SLA Battery
    Klipsch KG4.5 Speakers with Titanium Diagphrams and Sonicap Cap upgrade
    Please note that when passives work well, they're transparent to the source as long as the source output impedance is low and the amp input impedance fairly high, but some power amps don't like them and response errors and HUM can become an issue. Fancy attenuators tend to look and feel nice, but I'd check with a standard film pot first before shelling out hundreds on a posh Khozmo. It's not quite as cut-n-dried as it would seem and the pot value can make a difference to either source or the amp it's used with.
    I'm Paul.
    Hi David, so if enjoyed the sound of my Tisbury Passive much more than a recent active tube preamp I acquired and quickly moved on I might not necessarily enjoy the sound from my new BTE preamp? I've given Mr Cresswell details of my source and power amp equipment and he seemed to think it would work nicely. I must say I will be mightily disappointed if it doesn't at least match the Tizzy. My guess is that it will or at least I hope it will.
    Current system:
    RPi Allo Digione
    Quad 306 upgraded
    I'm Phil.
    Thanks for those salient bits of advice . Not had passive amps for some years while using modwright. However rather attracted by the freya as has valve and passive options . There is not huge differences but the passive is deadly silent and valve stage occassionaly gives a small bit of hiss or noise depending on which system I am using it in
